Doh... I didn't get a cable... and not sure the one included is long enough?
Dunno how far your pc is from the monitor do I ?
Dunno how far your pc is from the monitor do I ?![]()
You can use these at 75Hz with Nvidia? I thought it was only for FreeSync Gpu's![]()
Yes turn on FreeSync on the monitor, then just set up a custom refresh rate of 75Hz in the Nvidia control panel and you're good to go![]()
No stuttering issues or anything at 75Hz using Nvidia then? Is G-sync/FreeSync not needed? Ive never had either technology before you see.
I read in the 38" LG report today on TFT Central that Nvidia cards at 75Hz on that panel get stuttering.
welcome to the upper echelons![]()
Cant wait to break this out and have a little play of Deus Ex.
On another note. I just received the X34A but it says X34 on the box.
How do I know if I have received an X34A?
You'll be better off in this thread
https://forums.overclockers.co.uk/showthread.php?t=18687741&page=91
Thanks Spuddy.
why bother running when its frame skipping? wont be nearly as good compared to no skipping, physics!
