Caporegime
- 18 Oct 2002
Software, because you won't be getting any new hardware for 6 months
Software, because you won't be getting any new hardware for 6 months![]()
Not sure I'd feel as excited updating my "AMD Fuchsia Drivers"! Not sure about "Cerise" either.
https://en.wikipedia.org/wiki/Category:Shades_of_red
"Scarlet" or "Oxblood" I might be able to get behind.![]()
It's a bug, i have it with my Pro Duo's. We're on it.
Disable notifications (Radeon Settings > Preferences) as a temp fix to stop the message.![]()
It's not called Wattman on the Fury but I think it's basically the same overclocking software so I was using the name.Hows nash got it on a Fury then ?![]()
Overdrive in the past aka wattman didn't used to be enabled till you ticked the box and agreed to the terms.
They should also be an automatic fan control, seems to me you have it on manual?
I haven't touched anything overclock related in weeks as I run my gpu at stock and only stick an overclock on it when I'm doing a bench for a thread here at OCUK, This only started a few days ago.
I've already relayed some of the most common requests for new features, but if you have any contributions here would be a good place to post them.![]()
What does it say next to fan control? Manual or auto?
There isn't a manual or auto option, Just a target fan speed. Which I've had to manually set to 30% via the slider to keep it quiet.
Just to confirm this overdrive or wattman? I not used wattman yet but on overdrive I can choose manual fan or auto fan speeds.
Global Overdrive, but there's no manual or auto option for me.
Nothing, I'm hoping it's what AMDMatt was talking about when he mentioned a bug that they're working on but can't be sure until he responds.Scroll down?
Tried DDU and reinstall amd drivers? Not at PC atm to take a screenshot of my overdrive
That's just a waste of time if it is a bug, I'll at least wait until Matt answers and confirms one way or the other, Until then as I said I have it set lower manually now so if it is a bug I'll have to wait, no amount of re-installing's gonna fix it..
doesn't take long either.
