Any update from the devs on the patch?
They mentioned they would get something out in a few days last Friday.
Not that I can find, I just did a quick search around the Twitter accounts and nothing of note there from Harvey Smith etc.
To be honest if you guys apply the settings I used, the game works fine. If I can get the game to work for me on 4K and enjoy it, for the many who are still on 1080p it should be easy.
Even though I played with a controller for my first playthrough, I played 3-4 levels with a mouse on my 2nd playthrough and it works fine. End of the day the price is not going to be dropping in the next few weeks or even likely months, so if you want to play it you might as well buy now and try it, rather than panting waiting on a patch to come out![]()
Definitely finish it. The ending is brilliant!I'm quenching my thirst for fun FPS mechanics with Bioshock Infinite at the moment, about 2/3rds through, loving it.
Probably complete it before the patch comes out!
Mate - Ive tried every setting and combination of tweaks out there, and it just doesnt work properly. To be clear, and do pay attention, just because it works OK for you doesnt mean it does for everyone.
Pay attention to what exactly? I am giving my experience with the game here. Not forcing anyone to do anything they do not want. It is just information you either use or not.
Where have I suggested it works for everyone? There are not many people complaining for nothing, I had a rocky start to it myself. However there are many who are playing it without problems too, shall we ignore those people's experience because it does not work for you??
So how about you pay attention yourself to what is being said[/QUOTE
You said -'to be honest if you use the settings i use the game works fine'. No, no it doesnt, so dont arrogantly assume that it does.
One thing I read today that I haven't tried is getting the process in task manager to stay on High as opposed to Low.
Setting it to high reverts straight back to low the instant you resume the game, also alt tabbing degenerates the game further according to steam forums
Changing the setting using Process Lasso the setting remains on high so you don't need to alt tab, it definitely improved things for me but not a huge amount
I have to agree, there's something seriously up with the game. For a start Very Low looks almost identical to the higher settings bar textures as far as I can tell. Where's the scalability?! Using a controller or M&K and turning feels like it's got a huge amount of input lag attached. It's just a mess of a release really. If they release the patch and it doesn't fix things, I'll probably Steam refund as long as I'm in in time.
