Are these not the kind of questions you should have been asking your doctor?
Around 30 minutes on average, if you're claustrophobic you may not enjoy it.
My Doctor didn't refer me, he knows nothing about it.
I'm not claustrophobic. 30 minutes then, ok, thanks. Is that 30 minutes for the scan or 30 minutes till the results come in?
Who did refer you, as usually that person will receive the results and contact you later, rather than an as you wait results service?
My psychiatrist referred me. I understand that he will get the results but I was wondering if I would be told on the day by the MRI staff.
No, not usually.
A psychiatrist is usually a doctor, so a doctor did refer you.
It would be uncommon to get any results on the day, a report will be sent back to the referrer, and they will speak to you regarding it.
Usually.
I have had a couple before.
As others have mentioned it's a tight fit so claustrophobia might kick in.Oh yeah and it makes sounds like a spectrum loading and a 56k modem connecting on dialup.
No. My Doctor is my GP which is what you meant when you asked me. My GP has nothing to do with the patient care my psychiatrist provides.
