- 26 Dec 2005
- Manchester
Is it an acceptable score? I'm getting massive stuttering at times, literally just installed the card so I may need to do some tweaking. Also, despite the Radeon software saying it's the 8gb card (correct), Heaven thinks it's 4gb
If you look at all the scores in the table you'll find it's pretty much there or there abouts with similar systems. I've got a similar system and v similar GFX and clock speed. Think your CPU is a tiny bit slower
