6m long? How does that work? You hold that handle and there is a 6m long tube attached?
Its a flexible steel spring cord, you feed it down the pipe while turning the handle and the corkscrew on the front bites into whatever is blocking the pipe.
I've never understood why everyone's first instinct these days is to pour all sorts of chemicals down the loo when nine times out of ten a plunger/rod/gloved hand will do the job in half the time for a fraction of the cost.
Overclockers UK Forums > Life > Home and Garden > Blocked toilet?
helpimcrap
Capodecina
That 91% sulphuric acid stuff looks ace. If it doesn't clear the blockage, you could do it with your hands and then use it to sanitize them![]()
Your first port of call should be the nearest manhole cover to the toilet. Only once you've checked this is not blocked should you turn your attention to the toilet itself. Believe me I've unblocked more **** than you've imagined. We have our own mini sewage treatment plant here and I'm the maintenance man![]()
Do yourself a favour - Lift the cover off, then immediately back away and let it vent for a good 20 minutes before you do anything, just in case.If there is a problem then with all the acid I've tipped down i'll get someone in lol.
It might (or might not) smell bad, but you'll lessen the risk of being overcome by any possible fumes and falling (unconscious and headfirst) down a manhole to your death.
Might sound funny, but every year we lose a number of sewer workers who don't follow basic safety procedures...
Happens all too often.Damn, what a way to go.
