This is something I have wanted to try for a LONG time but only recently got round to getting a wired LAN setup in the home.
My setup:
Install games to Computer A:
C:\Games\Steam
Setup a network share for the "Games" folder.
Map the "Games" Folder to a drive letter (Z: for example) on Computer B.
Add "Z:\Games" as a Library folder in Steam.
That is it.
You can use Symbolic links if needed, but in this instance, mapping a folder to a drive letter did the job. If mapping a folder to a drive letter, the install folder you are wanting to share cannot be the root folder.
Anything installed to Steam on computer A is picked up on computer B.
Thus far, have tried TF2 and CS:GO and both ran fine with 3 computers on 3 different steam accounts running the same game from a single installation folder.
I expected maybe file access errors but nothing thus far, games just play fine.
If pushed, I would suggest maybe slightly longer load times, but am not certain, maybe placebo.
So far, seems a great solution if running multiple PC's on the same network, makes sense.
Will try with something Stupid like Arma 3 later.
My setup:
C:\Games\Steam
That is it.
), why would you want to do this?
This has only costed a few quid for cat6 cables and a switch I already had lying around. PC's already have SSDs as any PC should nowadays.
