- 19 Feb 2011
Way i look at it is this, if it matches the perf of my 4770k or even betters it but i get twice the amount of cores and it runs cooler, then for whatever price increase it is im all over it.
its obvious why because its slower.if it was faster than big intel chips you would be hearing about it.promotion is massive for sales.why would you not promote a faster cpu before release.its because its slower than the intel counterpart.
so its going to be slightly slower than intel counter part at a cheaper price.basically same as every other amd cpu release for last 15 ish years.
Still peddling that '15ish years' nonsense, i see. It's closer to 10 years, though admittedly it's still way too long.
Another thing that is slightly less obvious, but I think is also very important, is whether they use paste or welding under the IHS. If they cheap out there, then I'm afraid I may as well go Intel again in my next build.
It's still very misleading because Zen won't be clocked anywhere near as high as the FX series was, if 40% IPC is to be believed then a 3ghz Zen is going to be roughly the same as an FX9590 @ 4.7ghz, so given that clockspeeds are rumoured to be circa ~3.2ghz you're only likely to see a significant gain when overclocking (assuming Zen overclocks to 4ghz+).
As long as Zen has absolutely no performance loss per core over my Haswell, then it's a winner for me.
I guess I could stomach 5% slower core for core, if I end up with double the cores, but it depends on price.
Well unless AMD have made an exact replica of Haswell thats probably pretty unlikely to happen all the time. If you want a Haswell performance buy Haswell.
Intel already cheap-out on paste to bond the Heat Spreader.
So how would a 3Ghz FX 8 core get on with a 3Ghz 10 core Broadwell-E ?
