But rounded to the nearest 1000 would be 48000.
... And thus only fulfils one of the requested constraints, not both.
You need to find a number that rounds to 48000 as the nearest thousand and nearest hundred. 47900 only rounds to 48000 as nearest thousand.
Once you've grasped that bit, then you need to think about the other end of the constraint scale which says it should not round to 48000 as the nearest ten
