GTA V is actually perfect. If you don't drive carefully or are reckless, the police will come after you. Strap in to a VR headset and it's pretty terrifying.
Doesn't do wheel though does it?
Not being able to look around with your head (short of some VR setup, etc.) is a fairly big difference.
Something like Asseto Corsa with a freeroam mode and AI traffic (plus pedestrians, etc.) would be pretty close as far as it goes though.
Or being able to use clutch control and feel the biting point, the feel of grip in the road through the wheel, using the camber of the road for manoeuvres and of course the often idiotic and unpredictable pedestrians/drivers/cyclists.
There is no substitute for actual driving lessons. I don't think driving games would help a driver learn how to drive properly beyond explaining that 2 of the pedals are for power/braking and the wheel changes your direction.
I don't consider games/sims a substitute for actual driving lessons but IMO in some cases they could complement them - AC actually has pretty good (as far as it goes) reproduction of (dry) surface physics and the overall car mechanics - while only an approximation you do have to half properly use the clutch for instance in AC.
For me it was kind of the other way around though - after passing my test, etc. when I did spend time playing car games/sims I'd try and also use it to reinforce awareness, etc. i.e. getting in the habit of checking what I might be crossing into the path of before manoeuvring and so on even though you don't normally need to do that ingame - eventually you build that up with driving experience anyhow but doesn't hurt to have those kind of things dialled in instinctively.
I'd say get some L plates for your car, get her insured as a learner and take her out somewhere quiet!
I cant imagine any game at home would be remotely close to the real thing, even if the car in game behaves how a real car would, the whole 'experience' just cant be replicated. Unless you have some very expensive VR / steering wheel / rumble seat setup?!
actually just remmbered eurotruck simultor 2
theres probably a car mod that doesnt suck, has traffic and road rules
defualt traffic density is pretty low so thats nice
fyi a lot of the games you can get cheaper if you shop around, think bundlestars have rfactor 1 in a bundle thats like £1.90 for example
probably going to make people laugh but sim racers like Iracing and Rfactor have taught me a lot about understeer and oversteer and how to get around it.
