****Blender Ryzen render battle benchmark****
12 Jan 2014
Czech Republic
What do you need? First the render software Blender in version 2.78a
http://mirror.cs.umn.edu/blender.org/release/Blender2.78/blender-2.78a-windows64.msi
And after render scene:
https://ulozto.cz/!v5ELMDZKE3k6/ryzengraphic-27-blend this scene is with 200 samples predefined
AMD official render scene with 150 samples
In default is render test set to 200 samples quality. AMD útested the CPU Ryzen ES with 150 samples and also at 100. AMD RyZen 3.4 GHz 8C/16T got the scores
100 samples = 25s
150 samples = 36s
Show your results+info about samples and CPU-Z. Enjoy guys :)
26 Jun 2015
5820 K @ 4.3 Ghz
100 samples = 27.69
150 samples = 40.40
200 samples ( default) = 53.53
No other settings changed, only changed the sample number.
2 Dec 2005
Herts
5820 K @ 4.3 Ghz
100 samples = 27.69
150 samples = 40.40
So 11-12% faster than your 5820K, but running 20% slower clock speed with 33% more cores...
In terms of cores*clock speed advantage that works out as the Ryzen having 5% more, so the 6-7% gap must be architecture improvements. Not bad, but not amazing considering that's versus Haswell. Probably a dead heat against Skylake and newer.
Edit: were you running 6-way or 12-way? Isn't Ryzen supposed to be SMT as well? If you both had hyperthreading on it's a better comparison.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
AMD messed up, they uploaded the file with Default settings which is 200 Samples, the Ryzen benchmark was actually done at 150 Samples.
AMD uploaded the correct file here http://download.amd.com/demo/RyzenGraphic_27.blend
My result...
I have never compared my FX-8 CPU's to the 4690K but in terms of performance i didn't notice any diffrence...
Anyway.... my 4690K @ 4.5Ghz / 4.2Ghz UnCore / 2400Mhz 16GB CL11
Edit 150 samples, thats what AMD ran.
1:26.23
3.4Ghz 8 Core Zen is nearly 3x faster, impressive.
24 Mar 2013
C-137
I'll be giving this a bash on wide(ish) array of intel CPUs this evening :D
Though looking at these results, I think I can finally justify an upgrade from my 3770k, provided the performance uplift we're seeing is ubiquitous; across a majority of games & applications and we're not just looking at a best case only scenario :)
Deleted member 66701
D
4770k @ 4.8ghz
100 = 36.52s
150 = 53.89s
Hoping Ryzen does in fact turn out to be a viable upgrade route for me. Now I'm using Photoshop, Premier, After Effects and 3Ds Max extensively, a core upgrade would be worthwhile. Plus the fact I ran out of memmory editing a 1.5gb PSD file yesterday so I need more memory as well!
