Poor AM3+ owners, all they can get is Piledriver.
erm?
AM3+ can use everything AM3 and AM3+ , from the dual core Athlons to the 8 core 9590 (as long as it has enough power phases on the board ofc)
Richland was pretty much a none event.
Your AMD bias/Intel hate is absolutely rife.
Just because you buy Intel doesn't mean you're not biased.
Intel are factually ahead, it's illogical to not buy if you can afford.
erm?
and your bias is slapping you in the face with all your posts about not believing the live demo from AMD....
It was just overclocked Haswell. The only difference with Kaby Lake is that this time they've been bold enough to give it a new name and pretend it's a new architecture.Haswell refresh isn't Haswell though is it? It was enough of a respin that it got it's own name whether you acknowledge it as Devil's Canyon or not.
Broadwell can still be sourced if you are desperate for it.
Skylake has been out for over 18 months (aug 2015 release?), so the fact you can still buy any 1150 chips is surely unexpected good news for owners of the platform.
It was just overclocked Haswell. The only difference with Kaby Lake is that this time they've been bold enough to give it a new name and pretend it's a new architecture.![]()
Devil's Canyon was the same die as Haswell afaik, just pre-overclocked parts.
Intel the king of the CPU, AMD the king of the GPU but next year AMD will crush Intel on three's - CPU, GPU and price
Didn't Haswell have that TSX bug that caused it to be disabled for gen1 and was fixed (and thus enabled) in the refresh, effectively making Devil's a new line?
I think they also may have turned off other virtualization-related stuffs for 4770K but re-enabled them later in DC.
A lot of the APU stuff had this.
There's so much ignorance towards AMD with sockets.
Am3 was a sham, had no exclusive CPU, then AM3+ just turned up, no CPU's specifically for it. When they did come they were crap and you were stuck.
Then it's been left to rot since 2012.
Also, 1150 was Broadwell wasn't it? So it had 2 lines.
Also, woe is me being stuck on Haswell, I've enjoyed stellar performance for 3 years!
At least it was also called "Haswell Refresh" though, an admission of what it was.This time?
Haswell > Devils Canyon, it is the same thing![]()
