- 1 Dec 2015
Ensco 100 ( see how many can guess the meaning of it. Hint, off the coast of Scotland)
With a Budget of £750, following parts make their home
Jonsbo C3 Black with Window
Gigabyte GA-B150M-DS3H
Intel i5 6500
Gigabyte GeForce RX 480 G1 4GB
128GB M.2 Drive SM961
Toshiba P300 2TB 3.5''
BeQuiet Pure Rock 120 PWM
NZXT Hue+
Team Group Elite 8GB (2x4GB) DDR4
Kolink KL-500M 500W
Windows 10 Pro
Must say the C3 case is small! and the Quality is high as you'll see including wrapping all the bare aluminum in the case. The brush quality is the same as my Silverstone TJ07 and Jonsbo UMX4. Lian Li on a budget !
Window is darkened plexi, would have loved it to be glass but at the price its understandable - shouldn't be to hard to have one made really.
NZXT Hue will light it up nicely
RX 480 4GB will be leading the field, got it on a deal as someone forgot to update the black Friday prices
Hearing all the talk about it running hot and loud then other vendors- of course! its one of the only few that actually cool all 3 components on the main heatsink whilst being small and using 2 fans.
To help improve, Liquid Metal compound will be used along with better heat pads. Hopefully make some difference along with custom fan curve.
Was half tempted for the MSI but cooling put me off even though its quieter .
Never Used the Kolink PSU before but at the price, cant complain and is simi-modular - helping it edge out the beQuiet PSUs
Left protective film on for pics, not ideal but needs to be kept scratch-less
beQuiet PureRock Slim should be enough for the 6500
Case will be running Negative pressure, Is a larger filter on the bottom as well.
Intel i5 6500
NZXT Hue+
Kolink KL-500M 500W
Windows 10 Pro
