USB wall sockets
10 Nov 2013
I'm thinking about installing some wall sockets that have the built-in USB ports, and was just wondering if anyone has any experience with them? What are the downsides/drawbacks?
Do they require any extra connections compared to a standard socket? Do they continue to draw power when there's nothing plugged in?
No experience with this before so sorry if these are stupid questions!
I have them in every room of the house and they are so darn handy we wouldn't be without, saves on plugs etc decent output
Not sure if they draw unused mind you
Fitted some doubles each with 2x2.1A USB ports when we first moved in, to replace single outlets. Got one in the bedroom and one in the living room.
Haven't measured the quiescent power draw but it is likely to be very low, some even power off entirely when the USB cable is removed.
Thats interesting, i just assumed you would be limited to the standard 0.5 A. I didnt realise they would do more.
Thanks for the input.
Is there any additional wiring needed for these sockets, or would it be the same as fitting a standard 2-plug socket?
Exactly the same, everything is built into the faceplate.
Be aware some need deeper backboxes, mine needed 35mm.
I'd consider an MK branded one, but last I looked they were in the £20 region and required a 35mm backbox which isn't suitable for many of my sockets. Safety concerns from an unknown brand, and my OCD from having MK sockets throughout the house and another type not matching would stop me buying anything else.
Fitted a few in the house and I can't see one drawback!..sooo handy when you want to charge your electric toothbrush, fitbit, blue-tooth headphones and powerbank all at the same time! ;)
I honestly prefer the USB charging hub I have 2 USB c and 6 USB 3 ports all at full power. Have one in the living room and one in the bedroom.
So far I have tried the following USB sockets:
LAP (2.1amp double socket from Screwfix): Look decent, good quality, cheap and doesn't need a particularly deep backbox.
British General (2.1amp double socket): Look much the same as the lap and has similar dimensions. Of the two I have fitted one has broken (switch no longer works). Wouldn't recommend this one even though it is one of the cheapest on the high street.
MK (2.1amp double socket): Much better quality (as you would expect for double the price of the LAP/BG sockets), but requires a minimum of 35mm deep backbox which is much deeper than the others I have fitted. I bought this one as it needed to match another MK logic socket next to it. It's depth meant it had to be the spurred in socket rather than the one I spurred the new socket off due to lack of room for 3 sets of wires behind it.
I plan on getting some of the LAP 3amp ones for my bedroom when I decorate that. I'm not sure I would want USB C as I have so many different products that run off USB. I have bike lights that charge of the USB sockets in the garage, some USB sockets on the worktop in the kitchen (next to the Bluetooth speakers so phones/tablets can be charged while playing music. Most of the beds have USB sockets next to them for charging at night. The lack of fast charging is not a big problem next to a bed as whatever would be plugged in would usually be charged overnight so speed isn't that important. I still use my fast charger for my phone to give it a quick boost before going out.
Dave
Very helpful, thanks. Certainly sounds like the MK ones are worth the little extra. I plan on putting it into a new spurred in socket, so depth hopefully won't be an issue.
