**** The Official Google Nexus 6P Thread ****
Thanks - a timely reminder to update the backup on my PC.
Do you have a PC backup?
Yeah had one from July. So just downloaded the missing pics from Google photo. Added them to the folder and then copied back across.
Just concerned as to why the entire 10gb folder disappeared
Had to return my 5X as the charging port had melted the back of the case after 3 months - thinking about replacing it with a 6P...
Pixel is too much, what's the thoughts on the 6P? Still worth it?
6P or OnePlus 3T really. They both have pros and cons, but the 6P is still an awesome phone that still feels as fresh as day 1.
Can I ask where you got yours from?, they're still holding their price quite well and less people have them in stock now.
New ones are still holding their value too well - I went for a Grade A second hand one from a reputable trader on an auction site in the end. Cheaper than a new 5X, and came with a 12 month warranty.
Anybody been having battery shutdown problems with their 6P, just been testing mine currently at 21 percent still no shutdown.
Seems to be a good number people suffering from this once their 6P get to around a year old.
No i mean once the battery reaches a certain percentage the 6P turns off won't come back on until it's plugged into a charger, a lot of people have been having this problem even at 50 percent their phones would shut down, it more common around 10 to 15 percent of battery life.
No shutdown issue here. I can tell the battery capacity is getting worse but other then that the phone is as good as it ever was.
I get the battery shutdown fault quite often, on the verge of trying to live with it or trying to sort out a post-warranty RMA. But I've heard even refurb/new units have the problem too.
It's a dreadful issue, keep hoping it'll get fixed by software updates.
When I last read about the battery shutdown thing it was because the phone was too cold?
Haven't come across it myself personally.
Yeah I have but only when cold. Batteries don't like the cold so don't think its a fault with mine as doesn't shutdown indoors.
