Hi guys,
I got a 1080 GTX MSI Armor OC for x-mas along with a Seasonic Prime 750W Titanium and have horrendous coil whine.
Is this likely to be something I can get replaced or do I have to put up and shut up?
What's the chances of seeing a 1080 for less than £500 any time soon? That's my biting point!
ZOTAC announces GeForce GTX 1080 Mini
http://videocardz.com/65059/zotac-announces-geforce-gtx-1080-mini
They have been very good for me over the last 2 months, though never solved the coil whine issue. Choose the advanced RMA so I never had to be GPU less. Never had to pay for shipping however I'll lose money cause the collateral is paid via paypal in euros.
Never solved the issue though, with retrospect should have kept the Founders card I bought off you.
Black Friday was the only time they were £499.98 from a competitor. I dont imagine they will ever go that low, especially if Article 50 is filed in March.
Hey guys, does anyone know if the Gigabyte G1 1080 Gaming card is compatible with H-CUPERTINO2-H61-uA TX motherboard? I would appreciate any reply. I have the card and it's not going past POST however it has no problem running R9 390X.
"More info has become available during these months. You can just press Alt + F10 to boot it without the crackling noise. Pressing F12 without touching Esc also seems to work for some.
Simply just pressing F1 works, too."
Well I'm pretty sure that my 1080 Classified is suffering from the faulty VRM issue, Ingame it keeps black screening, Fans rev up to 100% and then resetting.
Time to test EVGA's legendary customer support.
I thought that was sorted a month ago? My EVGA 1080 FTW is amazingly cool after thermal pads installed. Couldn't be happier
Well I got the thermal pads, Installed them exactly how the instructions and video said to, Was running fine up until about 2 weeks ago when I started getting black screens, Fan revving to 100% etc....
Not a big deal, Doing an advanced RMA so won't be without
That's good to hear. It happens sometimes. Will your new one be same card?
