Should be fine, I've seen many SRAM cassettes on 8/9 speed shimano Giant setups, including my other halfs Liv.Super noob question... I'm thinking of changing the cassette on the winter bike from a 11-30 to a 11-28 as I don't like the big gaps you get on a 11-30 8 speed. I can only find a SRAM in those ratios, well... in shops that I have soon to expire credit notes anyway, so will that be ok as a direct replacement to the Shimano one? I'm 99% sure the answer is yes but after buying a cassette to replace a screw on freewheel in the past I don't put anything past me these days![]()
From the wording I think it's going to be more than just a 'Boardman' sales room, I'd like to think a 'cycling mecca' would cater to everyone and anyone, but we'll see!ooo wow! That's pretty close yeh! As at work I'm about 3 miles or so from that location.
Shame I no longer have a Boardman anymore![]()
You're obviously not putting out such huge power levels as we are...How do you all get through chains so quickly?![]()
It's probably just bad weather abuse, I know many of my low mileage chains were abused and probably changed before they should've been. I've never notably worn a cassette and the chainrings on my Defy have seen ~6000 miles, although they're showing quite worn now they are FSA soft-alloy and had quite a bit of abuse. Including, a 65 mile sportive with bad chainline/rubbing, cross-chaining commuting & at least one bad chain with a couple of links which gouged out lumps from them (encountered metal 'shavings' in my chain grime when cleaning!)
Expensive when it does!I expect the chain is going to take my cassette and maybe chain rings with it!![]()
I've never noticed wear on any of my cassettes, only chains and my FSA chainrings. My Praxis rings on the Diverge are showing no wear after 1700 miles (not that I'd expect to see any!) other than losing their black paint/coating on the teeth.
Zwift later, anyone else on?
