Deleted member 66701
Nice set up but the seat belts are a bit lolworthy, no?
Seriously though, it's all about immersion when you're racing in VR. Every little helps!Nice set up but the seat belts are a bit lolworthy, no?
You missed the gloves as wellSeriously though, it's all about immersion when you're racing in VR. Every little helps!
A few more Lego Dimensions sets for my boy.... and a couple for me![]()
) and ET packs.Whatshotguntoy gun are you using?
Thank you. The MKI which I made a few years ago wasn't sturdy enough so I made sure I built this as stable as possible. The front section is pretty much 3 sheets of 18mm MDF for the side panels with double thickness shelving and metal bracing for the wheel mount. It's monumentally heavy but I did design it to be reasonably modular if I should move house.
There's a pedal set on seat runners in the nose section to allow forward and backwards movement. The seat is also on runners so that's adjustable too. There are 4 Buttkickers - 2 under the seat, 1 under the pedals and 1 under the shifter for tacktile feedback (runs off software called Simvibe which converts telemetry information into feedback to simulate gearshifts, road texture, engine vibrations, impacts etc).
Under the monitor there's an Android phone which provides a simulated electronic dashboard (pretty much redundant now with VR). I used rotary dials, switches and buttons for various functions on the main dashboard panels. These still get used when in the Rift.
The cover at the back of the monitor houses an Oculus CV1 sensor for VR duties.
Decided to spoil myself for my 40th with a 2017 Whyte 905, as my old GT Chucker XS1 has seen far better days
Who stole the front chainrings?
and the fire extinguisher. or are you running a hefty overclock![]()
Hang on, you made that? Bloody hell, that's some fantastic work, well done![]()
These things are like gold dust nowadays. Finally got one delivered from Amazon randomly. Originally said they hoped it would be in stock 2-3 months, but only took 2wks to be delivered
Thanks and yes, it's completely scratch built - about 350 hours or so to build it!
