- 31 Jul 2012
- Cheshire
I really would like to know how all you guys setup the LED lights behind your screens, looks very cool![]()
USB RGB controlled strips are great too. I've used several connected to an old, powered USB hub which is connected to an RF controlled plug socket I had knocking around - handy for turning on and off easily. The good thing about multiple strips is that different colours can be used for a more interesting effect and the brightness can also be controlled independently. It also means that there aren't a bunch of wires connecting everything together.
I recently added some to the back of the monitor (both vertically and horizontally using 90 degree connectors) under the desk surface and under the PC stand I built and behind the monitor shelf pointing upwards.
It's a little garish with the lights off but I usually have the lights on anyway:
