So this Ryzen Infin8 system which is at CES, why haven't we seen this?
Same could be asked of all the other PC builders that demoed systems. I suspect they all signed similar NDAs.
The cat will get out of the bag when AMD wants it to.
even so quite impressed nothings leaked yet.
Gibbo is going to demo a Ryzen PC at CES?
Yes we built one for the AMD event and tested 8c16t. This does not mean we are saying anything!!!
8 pack chips are here, at 5.1/5.2
My god they are at a premium though.
I don't think I'd buy one anyway to be honest. '8 Pack stable' means not locking up under realistic use and might survive a stress test for 5 minutes but stress tests dont matter honest.![]()
But testing on 8Pack bundles is non avx prime with 3d also running, Real bench with full memory utilisation, XTU both CPU and memory stress with 3D running, Terregen renderring looped and Cinebench R15 looped one hour each as a bare minimum. Fine for all gaming and everyday use.
3d means a gpu load rather than a cpu load. games, benchmarks that are rendered in a 3d engine.What do you mean by 3D also running? Something like unigine heaven/valley running in the background?
Can you explain how you test with Terragen?
Testing on 8Pack bundles is on avx prime with 3d also running, Real bench with full memory utilisation, XTU both CPU and memory stress with 3D running, Terregen renderring looped and Cinebench R15 looped one hour each as a bare minimum.
To be fair a lot of users have come from the past as we have had no reason to upgrade. I came from sandy to haswell-e. I am still trying to find a stess test I am happy with. XTU was too easy and I was crashing in games (losing my progress at the same time), P95 and OCCT are absurd, and realbench doesn't always want to run with full memory and occasionally crashes at stock.
There are some x264 and x265 encoder apps that I will try.
