I can do 5.4+ on a couple of CPU (before delid) at low volts (1.35v) 2K plus and these CPU are yours ;)
We have a plan for a very high OC system 24-7 the testing of this concept starts on my arrival back from CES. Jumper you would approve ;)
I can do 5.5Ghz on my 2500K :p
The 265x 4K benchmark at HWBOT gets you quite close on these recent platforms. From my testing roughly on par with Realbench. The overkill test running multiple instances especially.
I had a play around with x265 but was a bit confused by some of the options. I didn't have much time with it though.
One instance per core is pretty brutal.
Here's 2x 4K. 6850K @ 4.5Ghz
I like the sound of it. :D
Kaby lake, what a massive fail. Intel sleeping at the wheel.. sorry could but this thread is one of the biggest anti climax launches in the last 5 years. Can't take your positivity seriously 8pack.. hopefully zen will liven things up.
We will see where Zen is but if it really does have the same IPC as SkyLake/KabyLake what Intel did here was insure they still have the per thread performance edge, at least on paper bumping the out of box clocks and refining it a bit so it overclocks a little more.
AMD's F4 revision 8 core used at CES runs at 3.6Ghz base and 4Ghz Boost.
Compare that to the 7700K @ 4.2Ghz and 4.5Ghz Boost, thats about 17% higher clocks, that is where reviews will show up the differences and its where Intel and Intel fans alike will point and say "see, Intel still better, Intel higher value"
I hope AMD 4 core 8 threads Zen is at least 4Ghz base and 4.2Ghz Boost, if it has the same IPC, because if its not we will never see the end of Intel justification bar-charts and i shall have to kill myself! :eek:
More footage of the ocuk ryzen PC from Paul's Hardware.
***WARNING: THE FOLLOWING VIDEO CONTAINS NAMES OF COMPANIES THAT OCUK MAY CONSIDER A COMPETITOR. VIEWER DISCRETION IS ADVISED.***
Lol it would have been better without the mass of bold yellow text. :p
I highly doubt they would have noticed.
^^But you don#t need Z270.
I dont get all these hatters of Intel 5.0+ 24-7 yes please.
Most of their rage is directed at the currency.
But even then, it's a boring launch, it does nothing to stimulate the CPU market. Maybe it does for you, but you're a completely different user.
