Man of Honour
- 29 Mar 2003
- Stoke on Trent
The cassette on my bike is a Shimano HG20-9 11-34, 9 speed, could I replace it with a Shimano HG300 9 Speed Cassette 11-32T?
Why do you want to change it?
Keep it and just ride more hills![]()
2 extra teeth on the gear, so a larger sprocket on the rear = lower gear (better for climbing).What is the difference between 32 and 34?
Probably nothing for my commute.
So should this cassette also be a direct replacement - http://www.halfords.com/cycling/bik...ain-cables/sram-pg-950-9-speed-cassette-11-32
That looks nasty.
4 years though, i'm not sure I've ever had a tyre 4 years!
Thanks for that.
The main reason for my question is that my gears keep missing and no matter what I do they keep jumping and my mate looked at my cassette and said it was my problem.
This evening I've given it a good scrubbing with a metal brush and it looks great and I also cleaned and oiled my rear derailleur.
I then looked at my cable and I think that's the problem, it was very hard to move in the shielding so I've bought another cable.
I also found another problem which wasn't there on WednesdayOh my God
They are Schwalbe Silento's, I've had them for four years and they cost me £25 each. Halfords are selling them for £11.
