The Pascal GTX 1080 Owners Thread
12 May 2005
This is crashing at stock? is it a full block your using?
Possibly a faulty card unless its still crashing because of high temps?
EK Supremacy HF universal block and numerous heatsinks over the VRM.
After trying the stock aircooler with MX-2 the card no longer crashes.
This makes little sense. Maybe it was sagging too much under the weight or there's a bad trace somewhere.
24 Aug 2013
Lincolnshire
Possibility, VRAM, VRM cooled via fan as well? Any reason you went that route over a full cover block?
If it is a bad trace (unlikely). Best bet is get an EK full cover block and backplate. Cools core, vrms and VRAM. Not to mention looks a lot better, are rock solid and will keep the pcb clamped nice and square.
https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-acetal-nickel-wc-9a4-ek.html
https://www.overclockers.co.uk/ek-water-blocks-ek-fc-1080-gtx-backplate-black-wc-9a5-ek.html
Permabanned
4 Sep 2011
Durham
Is it normal for these 1080GTX cards to reach 98C under load in MSI Kombustor in roughly 4 seconds with ice cold water flowing over the core with a freshly acid cleaned shiny VGA block?
Got the same results twice after rebuilding with EVGA paste and then AS5. Way too hot to risk using it. I've never seen temps above 60C on a GPU before.
Something is seriously wrong there dude! :eek:
My Palit 1080 is OC'd to 2000mhz and never goes above 70 degrees. Ever. Thats with the default fan profile of never turning on until it reaches 60 degrees as well.
12 May 2005
It's much better now.
The air cooler is holding at 62C at 2015mhz stock according to Afterburner. Getting decent FPS at 4K so far.
I don't think getting a full-cover waterblock for it is worth it, certainly not this late after release and given these cards barely OC at all.
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 19/01/2017, Make Gigabyte Turbo OC, BRIGGBOY81, Link
Date 11/01/2017, Make EVGA Founders Edition, SupraWez, Link
Date 09/01/2017, Make Gigabyte G1 Gaming, fozza_99, Link
Date 06/01/2017, Make Gigabyte Xtreme Gaming, Spikey, Link
Date 06/01/2017, Make MSI Gaming X, Darren777, Link
Date 05/01/2017, Make EVGA FTW ACX 3.0, terley, Link
Date 20/12/2016, Make Zotac AMP Extreme Spectra, stephenmarr, Link
Date 19/12/2016, Make EVGA Hybrid, bakes0310, Link
Date 11/12/2016, Make Palit GameRock, bayo000, Link
Date 30/11/2016, Make Palit Super Jetstream, hardkore, Link
Date 09/11/2016, Make EVGA Founders Edition, shahpor, Link
Date 08/11/2016, Make Asus Strix Gaming, b 2the enneh, Link
Date 06/11/2016, Make EVGA Hydro Copper, atomic7431, Link
Date 05/11/2016, Make Asus Strix Gaming, DW., Link
Date 27/10/2016, Make EVGA Classified Edition, Dicehunter, Link
Date 17/10/2016, Make EVGA FTW ACX 3.0, jonathan_phang, Link
Date 13/10/2016, Make Palit GameRock Premier Edition, ltron, Link
Date 07/10/2016, Make EVGA Hybrid, jkb, Link
Date 02/10/2016, Make EVGA Founders Edition, RSR, Link
Date 01/10/2016, Make Palit GameRock, Hugo_Sanchez, Link
Date 01/10/2016, Make EVGA Hybrid, MartyLewisUKD, Link
Date 28/09/2016, Make EVGA SC ACX 3.0, easyrider, Link
Date 27/09/2016, Make Gainward Phoenix GS, peahead, Link
Date 22/09/2016, Make KFA2 HOF, AWPC, Link
Date 20/09/2016, Make Palit Super Jetstream, Helios1234, Link
Date 20/09/2016, Make Zotac Founders Edition, pete910, Link
Date 18/09/2016, Make Asus Strix Gaming, BaDBoY_uK, Link
Date 14/09/2016, Make EVGA Classified Edition, hobib_ali, Link
Date 06/09/2016, Make Asus Strix Gaming, RSR, Link
Date 06/09/2016, Make EVGA SC ACX 3.0, Disco_P, Link
Date 03/09/2016, Make Zotac AMP Edition, Yevgeny, Link
Date 30/08/2016, Make EVGA FTW ACX 3.0, Calabi, Link
Date 25/08/2016, Make EVGA SC ACX 3.0, Hanga, Link
Date 24/08/2016, Make EVGA Founders Edition, Svack, Link
Date 24/08/2016, Make Clevo Mobile Edition, Meaker, Link
Date 22/08/2016, Make PNY Founders Edition, Disco_P, Link
Date 20/08/2016, Make Gigabyte G1 Gaming, ninjah, Link
Date 20/08/2016, Make EVGA Classified Edition, Spook187, Link
Date 17/08/2016, Make EVGA Founders Edition, wavehunter, Link
Date 17/08/2016, Make Palit Jetstream, KamalTMO, Link
Date 16/08/2016, Make Corsair Hydro GFX, Dazz182, Link
Date 13/08/2016, Make Zotac AMP Extreme Spectra, hyperseven, Link
Date 13/08/2016, Make MSI Armor OC Edition, Panos, Link
Date 12/08/2016, Make Zotac AMP Extreme Spectra, Spikey, Link
Date 12/08/2016, Make MSI Armor OC Edition, uksoldierboy, Link
Date 12/08/2016, Make EVGA Classified Edition, Trox, Link
Date 11/08/2016, Make KFA2 EXOC, psychas, Link
Date 11/08/2016, Make Gigabyte G1 Gaming, thedozyone, Link
Date 11/08/2016, Make Asus Strix Gaming, azazl187, Link
Date 11/08/2016, Make Zotac AMP Extreme Spectra, thedozyone, Link
Date 11/08/2016, Make Zotac AMP Extreme Spectra, bloodkil, Link
Date 09/08/2016, Make MSI Gaming X, wordy, Link
Date 08/08/2016, Make Zotac AMP Extreme Spectra, Shockwave, Link
Date 08/08/2016, Make EVGA FTW ACX 3.0, kthula666, Link
Date 01/08/2016, Make MSI Gaming X, Vertigo1, Link
Date 01/08/2016, Make MSI Sea Hawk, Mr Lahey, Link
Date 01/08/2016, Make MSI Sea Hawk, BOBWEISER, Link
Date 31/07/2016, Make Asus Strix Gaming, rogueblade, Link
Date 31/07/2016, Make Asus Strix Gaming, LoopyOrc, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, Drollic, Link
Date 29/07/2016, Make MSI Gaming X, ronski, Link
Date 29/07/2016, Make EVGA SC ACX 3.0, Five.Stars, Link
Date 29/07/2016, Make EVGA FTW ACX 3.0, PESolution, Link
Date 28/07/2016, Make EVGA FTW ACX 3.0, soundesciple, Link
Date 27/07/2016, Make Asus Strix Gaming, CrazyArsedMonky, Link
Date 27/07/2016, Make Palit Super Jetstream, adger1971, Link
Date 25/07/2016, Make Zotac AMP Extreme Spectra, marcus2704, Link
Date 23/07/2016, Make Palit Super Jetstream, Merisimus, Link
Date 22/07/2016, Make Gigabyte G1 Gaming, oaksmokedbacon, Link
Date 22/07/2016, Make EVGA FTW ACX 3.0, Day187, Link
Date 21/07/2016, Make Palit GameRock Premier Edition, titaniumx3, Link
Date 21/07/2016, Make EVGA FTW ACX 3.0, Valenni, Link
Date 19/07/2016, Make Zotac AMP Extreme Spectra, CauseanAffect, Link
Date 16/07/2016, Make EVGA SC ACX 3.0, roge8014, Link
Date 16/07/2016, Make Palit Founders Edition, nalfylatino87, Link
Date 15/07/2016, Make EVGA FTW ACX 3.0, Gee, Link
Date 14/07/2016, Make MSI Gaming X, Pappa-D, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Smffy, Link
Date 11/07/2016, Make EVGA FTW ACX 3.0, Simon Belmont, Link
Date 11/07/2016, Make Inno3D HerculeZ X2, bfar, Link
Date 09/07/2016, Make EVGA FTW ACX 3.0, jackle13, Link
Date 08/07/2016, Make Gigabyte G1 Gaming, ashmanuk67, Link
Date 08/07/2016, Make Palit Super Jetstream, oldestgregg, Link
Date 08/07/2016, Make EVGA FTW ACX 3.0, [Damien], Link
Date 07/07/2016, Make Palit Super Jetstream, Greebo, Link
Date 07/07/2016, Make Palit Super Jetstream, PDUK216, Link
Date 07/07/2016, Make EVGA SC ACX 3.0, Bulletzen, Link
Date 06/07/2016, Make MSI Founders Edition, GottiB, Link
Date 06/07/2016, Make Gigabyte Xtreme WaterForce, jommy999, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, jjgreenwood, Link
Date 04/07/2016, Make Palit GameRock, jackass3_16, Link
Date 03/07/2016, Make Inno3D HerculeZ X2, midweek, Link
Date 03/07/2016, Make MSI Armor OC Edition, vintage-x, Link
Date 02/07/2016, Make Gigabyte Xtreme Gaming, stulid, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, sativa1874, Link
Date 02/07/2016, Make MSI Gaming X, Rap1D, Link
Date 01/07/2016, Make Gigabyte G1 Gaming, Westie, Link
Date 30/06/2016, Make EVGA Founders Edition, adbee, Link
Date 30/06/2016, Make Palit Super Jetstream, Scottland, Link
Date 30/06/2016, Make MSI Gaming X, DougF1, Link
Date 30/06/2016, Make Palit GameRock Premier Edition, Merisimus, Link
Date 30/06/2016, Make EVGA SC ACX 3.0, fishyswaz, Link
Date 29/06/2016, Make Zotac AMP Edition, WesleyBurns, Link
Date 28/06/2016, Make NVidia Founders Edition, OCPete, Link
Date 28/06/2016, Make MSI Gaming X, sprite-, Link
Date 27/06/2016, Make Gigabyte Founders Edition, varkanoid, Link
Date 24/06/2016, Make MSI Founders Edition, latentjones, Link
Date 24/06/2016, Make Palit Founders Edition, VEGACORTEZ, Link
Date 23/06/2016, Make MSI Gaming X, PDArm, Link
Date 23/06/2016, Make EVGA FTW ACX 3.0, tomcoleman, Link
Date 23/06/2016, Make Inno3D iChill X4 Edition, Catanonia, Link
Date 23/06/2016, Make Zotac AMP Edition, PESolution, Link
Date 22/06/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 22/06/2016, Make EVGA Founders Edition, khemist, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, Jenkinio, Link
Date 22/06/2016, Make Gainward Phoenix GS GLH, sirleeofroy, Link
Date 22/06/2016, Make Inno3D iChill X4 Edition, PSeeBee, Link
Date 22/06/2016, Make Zotac Plus OC, $h@d0w, Link
Date 21/06/2016, Make Asus Strix Gaming, ThereIs0nly0ne, Link
Date 21/06/2016, Make MSI Gaming X, HungryHippos, Link
Date 21/06/2016, Make Asus Strix Gaming, Meteor, Link
Date 21/06/2016, Make MSI Sea Hawk EK, haszek, Link
Date 21/06/2016, Make MSI Sea Hawk EK, enigma27, Link
Date 21/06/2016, Make MSI Gaming X, Schwartz, Link
Date 21/06/2016, Make EVGA Founders Edition, rd_equals, Link
Date 20/06/2016, Make MSI Gaming X, Gripen90, Link
Date 20/06/2016, Make EVGA SC ACX 3.0, whyscotty, Link
Date 20/06/2016, Make MSI Founders Edition, MooKaNooBa, Link
Date 20/06/2016, Make Gainward Phoenix GS GLH, TheGez, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, BlakeySFC, Link
Date 19/06/2016, Make Palit Founders Edition, evensis, Link
Date 18/06/2016, Make Gainward Phoenix GS GLH, Matty8787, Link
Date 18/06/2016, Make Zotac Founders Edition, smogsy, Link
Date 17/06/2016, Make MSI Gaming X, Rasphelt, Link
Date 16/06/2016, Make EVGA SC ACX 3.0, Gripen90, Link
Date 16/06/2016, Make Asus Strix Gaming, grav, Link
Date 15/06/2016, Make Gigabyte Founders Edition, a66as, Link
Date 15/06/2016, Make MSI Founders Edition, Born_2_Kill_83, Link
Date 15/06/2016, Make Zotac Founders Edition, Hixxy0, Link
Date 15/06/2016, Make EVGA Founders Edition, jabski, Link
Date 14/06/2016, Make MSI Gaming X, Popov, Link
Date 14/06/2016, Make EVGA Founders Edition, Devious, Link
Date 14/06/2016, Make EVGA Founders Edition, Stelly, Link
Date 13/06/2016, Make Inno3D Founders Edition, CEUOTC, Link
Date 13/06/2016, Make MSI Gaming X, JABenedicic, Link
Date 13/06/2016, Make MSI Gaming X, Cochran, Link
Date 13/06/2016, Make MSI Gaming X, JLyte, Link
Date 11/06/2016, Make Zotac Founders Edition, avatar12m, Link
Date 11/06/2016, Make EVGA Founders Edition, crinkleshoes, Link
Date 10/06/2016, Make Gigabyte G1 Gaming, BriT, Link
Date 09/06/2016, Make EVGA Founders Edition, spiralz, Link
Date 09/06/2016, Make Gigabyte Founders Edition, WesleyBurns, Link
Date 08/06/2016, Make Gigabyte G1 Gaming, Gregster, Link
Date 08/06/2016, Make Zotac Founders Edition, Biffa, Link
Date 07/06/2016, Make Gigabyte G1 Gaming, Sasahara, Link
Date 06/06/2016, Make EVGA Founders Edition, Boomstick777, Link
Date 06/06/2016, Make EVGA Founders Edition, tyler_jrb, Link
Date 05/06/2016, Make EVGA Founders Edition, danw872, Link
Date 04/06/2016, Make MSI Founders Edition, easyrider, Link
Date 04/06/2016, Make Inno3D HerculeZ X2, LewisRaz, Link
Date 03/06/2016, Make MSI Founders Edition, DAIR, Link
Date 03/06/2016, Make Palit Founders Edition, Spikey, Link
Date 02/06/2016, Make EVGA Founders Edition, Radox-0, Link
Date 31/05/2016, Make EVGA Founders Edition, toon_mad, Link
Date 31/05/2016, Make Zotac Founders Edition, ToastedChip, Link
Date 29/05/2016, Make Gigabyte Founders Edition, kitkat9933, Link
Date 28/05/2016, Make EVGA Founders Edition, X-Mikuru_Beam-X, Link
Date 28/05/2016, Make Gigabyte Founders Edition, dvs8, Link
Date 28/05/2016, Make EVGA Founders Edition, passey89, Link
Date 28/05/2016, Make MSI Founders Edition, Biomorphs, Link
Date 28/05/2016, Make EVGA Founders Edition, RichardH754, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080.​
5 Oct 2009
Spalding, Lincs
Hi guys, seriously considering a 1080 as an upgrade to my Xfire 280x's now that I'm gaming on 1440p144. Quite like the look of the EVGA FTW card, are there any others I should be looking at? Looking to spend around £650 maximum really. Thanks.
13 Apr 2013
Scunthorpe
Got the 1080 put into the loop yesterday and I'm loving it so far. Playing DCS last night it was boosting to 1936mhz straight out of the box. Can't wait to start overclocking her and see what she can do. Temps were good to sitting around 38-40c at load. :)
13 Apr 2013
Scunthorpe
Had a little play last night and managed to put 100mhz on the core with 105% PL, which gives me a boost 2025. Also what is a good PL percentage for an everyday oc, I mean would it be safe to run it at 120% 24/7
30 Jun 2013
I believe increasing the Power Limit is not bad and is actually recommended to be turned up to max, 120-125% when trying to OC then dial it back.
I believe its the over voltage that it considered to be bad and is better to be kept minimum.
Correct me if im wrong though, not exactly the best OCer in town
13 Apr 2013
Scunthorpe
Both my 1080's under water :)
Together they are running happily at 2102mhz with memory at 11ghz. Seperate they both run at about 2132mhz.
2.1ghz is absolutely fine for me. Temps are low 40s at max. Also happy with this considering its about 30c in here at the minute. Lovely day today hense the late photo, Barbeque and ice cold beer's, nothing better :D
yeah pretty much the same clock speed and temps as well
26 Dec 2005
Paisley
What would be the best 1080 that would not give coil whine? Ive got a Strix thats pretty bad - i dont want to switch it out to something else if its going to be similar, its really annoying as its the only thing in my pc that makes any noise at all!
12 Jun 2013
Suffolk
It's a bit of a lottery tbh with cards and your pc setup. Noticed whine in a GTX 1080 in my media pc that wasn't present in my main pc. Same PSU manufacturers but diff wattage. Both 'gold' PSU's.
5 Oct 2009
Spalding, Lincs
Finally I can join the club :)
Boosted to 2025 out the box, and currently running +100/+450 with great results. Very happy with it.
