Caporegime
 - 8 Jul 2003
 - In a house
I know you mean well Shankly and you possibly cannot know what everyones tech level is but i had to take a deep breath there for a second. The answer is: ofcourse not. My monitor will tell me through its fps meter and so will the OSD. Its also on top of this very easy to feel and see.
the weirdest thing is for me personally Freesync is working in The division only if i use fullscreen window mode and driver 16.9.2 which doesnt support window mode freesync.. Makes no sense
Same thing here, on old drivers with FS working in fullscreen windowed.
By working are you basing this on the fact you see no screen tear?
Because Windows and windowed mode has forced vsync applied.
Shanks, tested Division earlier in Windowed (Full Screen) and Vsync is def off (Win 10)
what GPU are you using?
I think their are issues with the Div and DX12 currently, esp regarding windowed and fs modes. It's probably affecting it somewhat.
Some times nothing makes sense.
Like AMDs response times to Freesync and Division. At least from my experience AMD is good at this, and when they break something, they have new drivers in few working days fixing it. Right now we are 2 months with this issue.
I'm looking into this one.
Got an old driver issue, hoping someone can help with.
My other system that is just used for light gaming still has a 5850 in it. Recently the clocks keep getting stuck. The clocks are suppose to be 157/300 at idle and 760/1050 under load. For some reason though, the clocks keep getting stuck at 400/900. They don't clock up or down and just sit at that causing fps issues.
A reboot cures it, but it's annoying. The 5850 is a legacy card so is on the 15.7.1 driver which is the last pre-crimson driver. There is one driver after which is a crimson beta, but is bad and constantly crashes.
It never used to do it, the only thing that has changed between it starting this nonsense are being fine was a Windows update.
Any ideas? No other driver to go to. Is there a way to restart the driver without rebooting?.
