- 30 May 2009
- Maidenhead
I know some nasty bits north of Marlow. Some fun bits too though ^^ Never done Whiteleaf, but it looks nasty. By August I should have my climbing legs
Congrats on the job change and wanting to cycle that commute, much elevation? Commuting is a great way to rack up miles, ask Von how much his increased! Similar length commute too?!
Your roads are perfect in comparison with most of the country! I nearly hit a squirrel this morning. Pot holes big enough here that wildlife are using them for winter nut storage!
Traffic maybe worse but your weather is warmer!![]()
I blew up a tyre before xmas near central london, pothole killed it! we've got holes all over the place! I hit a pigeon more than once too
I wrongly had 4iiii pegged as a cheapy alternative to Stages but with some serious WT teams riding them (with only Sky using Stages?) there must be a reason. Maybe I need to consider them!
Your roads are perfect in comparison with most of the country! I nearly hit a squirrel this morning. Pot holes big enough here that wildlife are using them for winter nut storage!![]()
is far from ideal, I'd rather ride in quited country roads with a few traffic lights and potholes than deal with this cack![]()
Hi all, Need to ask a dumb ‘starter for 10’ about HR zones.
To find my max HR, does it matter if I run instead of cycle? Most of the things I’ve read online hint/presume I would be cycling to find it out, but I can get higher HR rates running.
On the face of it, I don’t think it would matter, but if HR training zones are calculated specifically/tailored for cycling, then id be entering a number that isn’t reachable. Difference is about ~20bpm IIRC.
Pretty solid for base training just do longer & more intensity on weekends! Although depends on the IM course, most of them are fairly average elevation but heard of some really flat ones which suffer more from wind than anything else.Cheers, it's 800ft on the way there and 1000ft on the way back so pretty flat thankfully.
Wouldn't have considered cycling if it was a really hilly route at that distance. I'm planning on doing a Half Ironman later this year so the commuting will really help the base fitness and then just need to do longer rides on the weekend.
I don't think it matters for max HR, but I would be cautious of the zones as you may find that riding at tempo is then your threshold. Do a few more manic interval turbo sessions and you should start to see your bike HR hitting those high levels. At least spikes of it.To find my max HR, does it matter if I run instead of cycle? Most of the things I’ve read online hint/presume I would be cycling to find it out, but I can get higher HR rates running.
Oh I'm sure you guys see more frequent large potholes, you have such a huge number of cars on the roads to cause any small hole to develop into a crevasse within a short time. Here the roads are just badly maintained - rough patches of tarmac don't get fixed, gutters overflowing due to blocked drains and mud all over the roads due to all the agricultural vehicles. Most of lines worn away/non-existent or hidden by mud and the broken surfaces/pot holes only getting repaired when they've been there a number of months and grow large enough to damage a car tyre in. The ones that don't grow never get repaired!you sure?I blew up a tyre before xmas near central london, pothole killed it!
Probably. Several also using SRM and Pioneer, only one using power2max and none using Powertap/Garmin! In the public space Garmin and Powertap seem to be the big names followed by Stages (mostly due to them being so cheap in the US?).Think a fair few in Sky are using dual-sided Stages (unavailable to consumers) and maybe same for 4iiii?
I've just had an e-mail from Canyon informing me of delayed delivery of my bike; due to 'issues with supply of external components'.Canyon being their totally enraging best. £7 to deliver a nut and bolt which has taken nearly a month from the initial contact till now and it's still not bloody here.
When you consider things like frame brands the WT 'known' huge bike manufacturers (Specialized, Canyon, Giant, Merida, Cannondale etc) tend to match the brands you predominantly see out & about, with lots of otherwise smaller brands (Pinarello, Factor, Condor, Boardman etc) either trying to get their names into the WT, or seeing a large scale of their business/recognition coming from being ridden there.
Chilterns ride in August/Septmber sounds ace! Count me in!
We're Everesting Whiteleaf![]()
#dead
What we could actually do, in a similar sort of fashion to my club runs, is have a set 70, 50, 30 miler route and aim to pass by particular locations or loop back on ourselves at certain times to pick up fresh legs, so those not wanting to do the longer ride(s) (or time constrained) can do a distance/speed more suited to their fitness.
The club actually sets off at the same time and rides slightly different routes at different speeds but all finish back at the same location at the same time.
I know the area relatively well so can plot up plenty of friendly (read: punishing) routes![]()
Haha yeah, similar to OMS waiting 3 months for a nut & bolt!We joked about it before, but considering Canyon's track record, you may have to prepare yourself to wait like 6 months!![]()
Yeah Boardman now sponsor One Pro, a good move. Equally I've seen several Boardman's around, even good riders regularly riding them (rather than the Halfords 'c2w' lot). They're seeing a bit of a resurgence recently too, glad for them as they got a pretty poor rep from Halfords shifting them before, just now being seen as a quality brand!I actually saw a Factor out the other day. First one - I think Boardman took over from them for One Pro Cycling though?
Oooh what's that? Fabric Line.Don't like saddle on new bike, fixing (hopefully) with this:
I suspect it's going to be firm, but fair.![]()
eek
Interested how you find it, I did try a Fabric Scoop at my LBS but didn't find it any different to the Charge Spoon I was riding at the time.
