Yes and test Doom only in OpenGL since that is the most taxing. You can't fault that kind of logic.
Yep, this aint no conspiracy. We just need to do anything to keep them AMD fps numbers down.
I think it's called being leaned on
You're still not getting it...The graph posted in the OP was taken off the site because it is wrong. All is explained in the conclusion.
Some people just don't have the capacity to read what is in front of them, which is why arguments happen.
If you consider Open GL a setting up from Vulcan then go ahead to think that.
I consider Vulcan a setting on, using Open GL in that game is literally taking a setting off.
Sorry but that is utter nonsense.
Vulcan is literally a setting one up from open GL, also a lot of reviewers do seem to provide both APIs results.
Why would you use a -1 setting in a performance benchmark anyways?
I am curious if any of you who fight so hard over these results have actually played the game even once![]()
No.
Vulkan is a renderer as is dx11, dx12 and OpenGL is. It says how the graphics cards will render a scene depending on its architecture and it's features. So obviously, since nvidia and and cards have totally different arcitechturea some cards are going to run better on one platform than on another depending on what features the gpu may or may not have.
Judging by how aggressive he got on the Guru3D forum when someone challenged him I suspect he will do no such thing.
Then that becomes a tweaking guide, not a Performance benchmark, benchmarks always have max settings and the latest features.
Again I ask, why would a reviewer reduce settings or use older settings for in a PERFORMANCE BENCHMARK, this is not to be mistaken with a tweaking guide.
Have you got a link to this forum thread as I cannot find it right now.
thanks
Yep totally agree. With both graphs shown (Original and Current) it would have been Nvidia mindshare that would have been rekt. (Okay, dented)
Most people just skip to FPS and the graphs, which in this case would have shone a different light overall to the majority of users IF the original graph had been left in to go with the explanation. It certainly would have swayed a few looking into getting either a 1060 or a 480/390X
It alters the perception for sure in regard to current mindshare.
As for Guru3D, lets just say they know which side their bread is well and truly buttered on.![]()
The review author deleted all the posts.
There isn't much in there, just what agrees with him or at least isn't critical of the review http://forums.guru3d.com/showthread.php?t=412306
The rest he deletes.
Do you have proof of these so called deletions, screenshots, linked to cached pages etc?
I've just cleaned up this thread and said goodbye to one more user.
I'll repost what I stated earlier. There have been an unfortunate three revisions of the benchmarks with results all over the place. The last batch is the most valid. The Shadow Cache settings disabled offers the best game-play for the majority of cards hence it is the preferred and recommended setting, for 6GB and upwards shadow cache enabled can offer better results, use it at your own peril.
In-between revision 1 and 3 of the review a lot has happened, new drivers 5 minutes after I posted the article, totally weird anomalies but also an error on my side that boosted perf on the earlier tests. I think this was the cause of my having interlaced modus activated (mistakenly) on some of the cards as I have been goofing around with that on day 1. Totally my bad, but I am not even 100% sure either that was issue as the game remains difficult to measure.
A mentioned several times now, I will retest the game in a few weeks when the drivers on both sides have mature and when the game has had a patch or two. The initial results up-to revision 3 have been far from ideal, but the rev3 results do match what you guys should get gameplay / FPS wise closest.
I have also retested an rx480 with both the shadow cache on and disabled. The perf differential is not far away from each other really. However on the opposite side, going to a 4GB card with shadow cache enabled brings in issues, stutters and game perf differences as shown in the FCAT results.
That said, the results as they stand ever since yesterday evening with rev3 stand and are sound.
Last thing, I am getting very tired of the attacks on my personal account here. I spend hours offering you guys un-biased results. Commenting is absolutely fine as mistakes do happen. But the verbal attacks lately are beyond what I deem is acceptable. The near sociopath behavior that some of you guys have been able to witness from the two users is just unacceptable. It partly comes with this job I know, but please do have some respect as I certainly do not deserve the incredibly crap that has been outted here.
Thanks guys.
