Heard lots about this myself, but personally never experienced it. On 7.1.1 too. I'm curious to know why some get it, some dont.
I let mine run down to 10% today to see if it shut down. But nothing.
I'm also in the Beta program.
As far as I am aware if you bought it from the Google Store you are entitled to a RMA/Replacement.
Anybody been having battery shutdown problems with their 6P, just been testing mine currently at 21 percent still no shutdown.
Seems to be a good number people suffering from this once their 6P get to around a year old.
As only occurred when the outside temp was -3c I'll see how it goes. I'm up in Scotland this week so if happens again I'l RMA it.
If you are on 7.1.1 the beta program has ended now. If you reboot the phone you shouldn't see the beta screen. Lets hope they do some more updates.
Are you guys with battery problems running stock 7.1.1? I'm on a custom ROM and don't have any issues. My battery will go right to 0 before turning off.
Mine updated to 7.1.1 (Jan security updates) yesterday and I used it as normal.
Plugged it in last night at around 22% battery and it started flapping charging/draining and destroyed 15% battery in about 10 minutes doing that. Had to do a hard reset before it would start charging properly.
Handset itself is about 6 months old, and hasn't displayed any whacky battery behaviour so far, so it appears to be software at this point possibly.
mine just came back from repair for faulty headphone jack...
all they did was software reset it.... sooo mad right now!
So Three now support Wifi calling, how do i enable this on the phone. I cant find the option.
They have indeed, it very useful where I live considering I have no signal but FTTP!They've had their three inTouch app out for ages now no?
