1st off - I tried to use "quote" to quote you, and I got the initial quote you used in your post - which to me is very bizarre (apart from the fact as a user you press"+quote" as normal and then have to press "insert quotes " at the bottom which should be redundant if you only want to quote one person
(didnt have "reply" button , only trust and quote)
It may be "hugely improved" to moderate - but as a user / reader its pretty horrendous , apart from anything else no DIRECT link to sub forums having to fully expand pictures to make them legible rather than having them correct size to start with
edit - also lost a number of posts from post count (no biggie, just interesting - Im guessing those actual posts have disappeared also)
We're having to use/read the forum too so I'm not ignoring the functionality issues being raised, just saying that change was needed as it was an issue with the old forum.
