- 4 Oct 2005
- Herefordshire
Well i have a 4k tv, but the audio is a all in one a Sony BDVN7200WB.CEK(bought it without looking at the options), anyhow it is a right royal pain in the backside, i am having various problems with the system, to late to send it back now and me now being skint im having to save for a "proper av system"
The speakers i am thinking of getting are the following :
Front left : Q Acoustics 3020,Q Acoustics 3010,Q Acoustics 2020i
Front right : Q Acoustics 3020,Q Acoustics 3010,Q Acoustics 2020i
Centre : Q Acoustics Q3090c,Q Acoustics 2000Ci
Subwoofer : Gemini 2 from B.K. Electronics
Rear left : Q Acoustics 3020,Q Acoustics 3010,Q Acoustics 2020i
Rear right : Q Acoustics 3020,Q Acoustics 3010,Q Acoustics 2020i
For Atmos : Onkyo Skh410 Atmos Speakers
If i decide to go 7:1 i would add another 2 Q Acoustics 2020i
Tbh im after some advice i am not really sure if there is a big difference between the series of Q Acoustics ?.
I chose a different sub becuase i have read the one from Q Acoustics is not that good, is the one i chose going to be good enough for the rest.
Reason for choosing Q Acoustics i hear they are a good budget set, have good reviews ect ect (except the sub) the only way i can afford to buy the above is by saving(using the rainforest, top up account jobbie) not perfect i know but its th eonly way i can do this at the minute lol, i thought i woudl get the speakers first then i woudl get the av amp after.
Anyhow up for advice, i dont mind for example getting the Q Acoustics 3020 for for the fronts and say the cheaper ones for the back, woudl this work be ok, the series is also wife friendly.
. Then again you can do allot with up firing speakers, just the Onkyo aren't a great example of them.
