Wow I just turned off my custom theme and its looking good!
Really not much in it now.
Just need to get rid of the avatar, username, and post count next to the reply box, and we'll nearly be there!
/* removes the nasty big header */
#logoBlock{
    display:none;
#headerMover #headerProxy{
    height: 50px;
    margin-top: 20px !important;
/* removes the user profile by quick reply box */
.quickReply .messageUserInfo {
    display: none;
/* removes the facebook/twitter share icons */
.sharePage {
    display: none;
.sectionMain {
    background-color: rgb(28, 87, 128);
   /* padding: 10px;*/
    margin: 0px auto;
    border: 0px solid rgb(255, 255, 255);
    border-radius: 10px;
.node .nodeDescription {
    font-size: 11px;
    font-family: verdana;
.node .nodeStats {
    font-size: 9px;
/* removes the facebook logo by post number*/
i.fa.fa-facebook-square {
    display: none;
.discussionListItems .unread .title a {
    font-weight: 400;
    font-size: 12px ;
.pairsInline dl, .pairsInline dt, .pairsInline dd {
    display: none;
/* Removes avatars */
.UserRankImages {
    display: none;
/* removes the background and white borders around the gangster title */
.userBanner {
    font-size: 11px;
    background-color: transparent !important;
    border: 0 !important;
    border-color: rgb(200, 200, 200) !important;
/* corrects the padding of the page links when there is more than 3 numbers, e.g. page 580 now fits in the box correctly */
.PageNav a {
    min-width: 14px !important;
    padding-left: 3px !important;
    padding-right: 3px !important;
.PageNavNext, .PageNavPrev {
 height: 15px !important;
    padding-top: 0 !important;
/* Remove discussion and post amount */
    display: none;
.subForumsPopup .dt {
    margin-left: -5px;
/* Smaller title font in Thread */
.titleBar h1 {
    font-size: 11pt;
.messageList {
    border: none !important;
/* reduces padding between posts */
.postDate {
    padding-bottom: 0px;
    padding-top: 0px;
    border-right-color: #373f44 !important;
    border-left-color: #373f44!important
	Ta da!This might be an excellent feature, did I notice an alert setup in our profiles that alert you if your comment was quoted?
I hope so because that's a fantastic idea.
The 'search this forum' feature was quite handy and seems to have gone. It was a simple way to search for 'paint', for example, and get results relating only to home and garden rather than including results from motors.
I know there's a workaround in terms of selecting only certain forums to search in, but it's more of a faff and the previous solution was quick and simple.
I realise we can't have everything, but if it's a quick and simple addition, it would be appreciated.
Are we going to get a dark theme? rather not use third party extensions.
We have something in mind - if it works you should be able to tweak your own design.
Dark theme will be a standard selectable before too long but I accept you can't please everyone.
Ill repost because I don't know if it's been seen or not. But in mobile view while viewing a thread, I'm able to swipe the page left and right. It just makes browsing a bit more difficult when fast scrolling through threads, as the page bounces all over the place. And often stops scrolling.
Not sure what you mean? If I swipe left or right in this thread for example nothing happens. Are you suggesting the thread isn't filling your window?
If I'm reading that right, you want an additional icon to do something that there's already an icon there to do? I've not raised it but I think it's unlikely that will happen as it's just duplication.I know now the thread title goes to the first page which is great and the envelope icon goes to the first unread post. Is there any chance we can get the little icon reinstated that was at the end of the thread title to go to the first unread post? Pleeeeeeeeeease.
Are you using a theme at all? I've checked that with a couple of browsers and I'm not seeing it at all.Certainly looking good a lot cleaner. If i can be pain, sorry if it has been said, couldn't see it in OP .
I think it would look better to have a couple of pixels of padding to the left hand side of the unread post icon, looks a bit strange pushed all the way up to the border.
