- 18 May 2010
- London
IMO - Ryzen is a rubbish name. Zen is much better. Ryzen is tacky!
Ay??? thought the was all the same chip ect. just the clock speed is the only difference ?
I'm going 2666 C13 - Cant find a single DDR4 test/review that states going any faster is worth the extra money
I don't know why people are so shocked by this, most (but not all) of the leaked benchmarks we've seen show Ryzen either matching or beating Kaby Lake for IPC.The hype tram is moving to faster than scooter speed now:
http://wccftech.com/amd-ryzen-1700x-benchmarks-leaked-beats-kaby-lake-ipc/
Going off Gibbo's post about getting the 1700 to 4Ghz I have some reservations about pre ordering.
You can buy a 1700 for £319 + expensive X370 mobo (Gibbo states the B350's arent upto the job) for £250+ so £569+ and OC to try and get 4Ghz.
You can buy a 1800x for £488 + cheap B350 mobo for £80 so £568 and get 4Ghz.
With the 1700 you might end up with a lemon so not reach 4Ghz.
With the 1800x if it doesnt at least get 4Ghz advertised speed you send it back?
With the 1700 you end up with a more feature rich mobo if you need all the extra options but with the 1800x you could always upgrade the mobo down the line.
Without any real information its crazy to buy until benchmarks are out.
And because the 1700 looks like the best value for money product, if you buy a good motherboard.......
http://wccftech.com/amd-ryzen-7-1700-overclocked-4ghz/
The hype train is now an EMD SD90MAC. If the 1800X overclocks a 10% at least then it will be transformed to a EMD DDA40X and be unstoppable.
(those who know about trains will understand, but I am referring to the most powerful engines ever made, a 6000bhp and 6600bhp respectively).
Which is the best B350 motherboard?
My current build:
£12.95*
Corsair Vengeance LPX 32GB (2x16GB) DDR4 PC4-21300C16 2666MHz Dual Channel Kit - Black (CMK32GX4M2A2
£239.99*
Considering dropping the processor to the 1700x
Poor gibbo trying to be discreet and they go and use his words
 A quick general guide to understand the RAM speeds and timings, because both represent how good the memory module is.
lets take for example my RAM.
3600Mhz CL16-16-16-36 it's equivalent performance module at 3200Mhz should be CL14-14-14-34, any timing higher (eg CL15) is slower module.
4000Mhz CL18 is equivalent performance module as the other two above.
So taking that as rule of thumb,
3000Mhz CL14 ram is slower than all above
3000Mhz CL16 ram is slower than all above (incl 3000C14)
2866Mhz CL15 is even slower than all the others above it (incl 3000C14 & 3000C16).
and so on.
Buying a good module, you can down clock it and apply tighter timings. Eg the 3600C16 can run as 2800CL12 or 3000CL13, and if lucky 3000CL12 without adding power.
And here comes the overclocking.... adding extra power (and having good cooling) and if the the 3000Mhz CL14 is good (example), can do 3200CL14 if not 3333CL14, so you get better performance.
I hope that helped.
Indeed, hadn't read the article :/OMFG you're linking to wccftech who are giving their source as this thread
Indeed, just looked at the article
So that means someone from in here feeds WCCFTECH???? Who's the mole?????
 im leaning towards the same mobo and cpu myselfI think I'm settled on the following..
My basket at Overclockers UK:
- 1 x AMD Ryzen 7 Eight Core 1700X 3.80GHz (Socket AM4) Processor - Retail= £389.99
- 1 x MSI X370 Gaming Pro Carbon AMD X370 (Socket AM4) DDR4 ATX Motherboard= £169.99
- 1 x be quiet! Silent Loop Superior Liquid CPU Cooler - 280mm= £136.99
- 1 x Thermal Grizzly Hydronaut High Performance Thermal Paste - 3ml / 7.8g= £12.95
- 1 x TeamGroup Dark Pro 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black/Grey (TDPGD416G30= £139.99
Which 2x16GB sticks do you recommend?WTH s that memory, 2666mhz cl16 ?, for that frequency you can get cl13, if i were you i would change the memory, with tighter timings
They all support XFR!!
Gibbo states that u need a high end board because these cpu are a challenge for the vrm.
We have seen down clocking on lower end models.
I had a 4930K @ 4.5 was doing great rendering job, however compared to the 6700K @ 4.7 was anaemic when came to gaming, buy a good margin.(same applies to the 4820K @ 4.9Ghz)
Especially in WOT which is single thread game, even the 4820K @ 4.9Ghz is trashed by the 6700K @ 4.7
So I will wait and see. If Ryzen 1800X doesn't overclock well if at all at 4.5 with good WC system (dual 480 rads for example), then I will pass and wait for Zen+.
Even if I am excited by the overall performance of the product.
Because overclocking is a a good part of what I want from a product. If cannot be done, why are we here???? Lets change the name of the forums to "stockclockers" and be done with it........
Why we spend all that money on fancy watercooling if not for the fun of overclocking and the hobby overall?
We could just go value for money, and use a console for all our gaming.........
