- 5 Sep 2011
- Surrey
I will bet a bag of haribo sli will work on them..
lol, deal.
Then buy one with SLI support, its written which boards do and don't support it in the specifications list, i for one am happy to pay a little less for one that doesn't as i will never use it.
Your negativity in this IS unwarranted.
Why do they have 3 different cooler types if only one CPU comes with a cooler? i'm not disputing the fact its just odd to me.
Apparently there is a hardware fault with the ryzen cpus which will require re-manufacturing....Some drop of info from the AIDA dev:
Many review sites have problems, as a lot of boards have buggy BIOS etc, which the manufacturers trying to iron out as fast as they can.
Plus there is some strange things going on with the Ryzens cache/memory latency, it's very high. The speed is great, but the latency is not so much, sources yet unknown.
probably for 6 and 4 cores without XFR , my guess any Ryzen ending with X wont have a bundled cooler.Why do they have 3 different cooler types if only one CPU comes with a cooler? i'm not disputing the fact its just odd to me.
On top of all of that, OCUK are talking about overclocking but were they not using an AIO while also talking about VRM issues? So the question I have is, did they have any actual directed airflow at the VRMs. Largely because they are all designed with these stupid flat tops which prevents a lot of airflow. Really you want a cooler blowing down onto the board, either fan on top of a heatsink such as the 1700 stock cooler, or a fan somewhere to blow air at the board and which would then blow through the VRM heatsinks.
Will be the sub timings.
Well this only seem to affect them in cache latency benches, and compression benches (7zip and alike)
Or maybe it won't??? You don't know that
I think the idea that you need a £250 mobo to overclock well us utterly ridiculous and frankly don't believe it, I'm wondering if their testing method was simply faulty and didn't cool the VRMS, hence only the stupid expensive board with cooler running/larger number of VRMs worked well.
In the PassMark benchmarks results from a week or two ago, both the Physics and Prime test results were poor. RAM speed is an obvious cause but it'd be interesting to know if this supposed cache latency issue is also related.Guess that somewhat verifies the CPU/Memory Mark leaks featured here:
https://www.youtube.com/watch?v=kPaxjsrWT_k
