ouch... no delid AMD CPU's, they don't need it anyway, they don't use crappy tim, they are soldered.
There is a picture of one 1800X delided. Painful to see the state of the core after forcing the soldered heat shield off. Assuming is a 1800X.
but according to AMD they are soldered. No cheapening here....
I don't care how they overclock, out of the box performance is what matters most.
The days where the 1GHz and 1.2GHz thunderbirds were the same CPU with diff multiplier settings has passed, overclocking is more complicated these days and even round here most people can't be bothered with it.You're on the wrong forum.
--------------->>> stockclockers.comYou're on the wrong forum.
I agree, but performance is rarely freeI agree, but a little free perf is always welcome![]()
These days I prefer rock solid stability over an extra couple of FPS.
Well then you have missed how both the Core i7 4790K and Core i7 7700K are essentially pre-overclocked SKUs from Intel with only a relatively small percentage overclock headroom.
Compare that to a Core i5 2500K which was comparatively underclocked.
The fact is if you need an expensive motherboard to get those maximum overclocks on any CPU,its not really worth just for a 10% increase over boost clockspeeds.
If I was getting a Core i7 7700K today,I probably would not bother with an expensive motherboard and just run it at all cores Turbo.
Your on the wrong forum too then. We want max overclocks!![]()
My old B3 stepping was a space heater, brilliant fun! I bought it when everyone was saying to get an E6600 as more cores were a wasteYou want to try some fun - I had a high VID Q6600 in a 975X based Shuttle with a modified Shuttle stock cooler.
I remember those well......Ahh man, My Celeron 300A , that was a beast, knocked the stuffing out of a PII450![]()
With any luck that's what the 1700 isThey should release a special "overclockers dream" SKU. Same as an 1800X just running at 2.8GHz out of the box. You can have all the fun of getting it to 4.2 yourself![]()
I remember those well......![]()
My old B3 stepping was a space heater, brilliant fun! I bought it when everyone was saying to get an E6600 as more cores were a waste![]()
