So can expect 4.0-4.7Ghz from a 1700 then![]()
Reading between the lines, Gibbos original post was about the 1700 (non-X) and that has a base clock of 3GHz. So at worst his +1000 implies they should do 4GHz.
I run it at 1.0833V @4Ghz, with the single Noctua fan having a range of 900RPM - 1200RPM.
I tried both Thermal Grizzly Hydronaut, and Noctua NT H1, and the Noctua paste was easier to apply, and was 1-2 degrees better under max load.
Encoding a small 4K 60fps video at 68Mbs, and it's nice a cool; ambient room temp at 18 degrees at the moment.
Here's the temps from AIDA64 when I first replaced my H110i GT with the D15S.
All i will say is i use handbrake and that pegs each thread/core at 100% usage.
looks more like a house than a pyramid
house of zen
@Gibbo
I know motherboards aren't your thing, but are you aware of or can you get any info on OCUK's stock for those that have pre-ordered the top-dog?
TIA
House of the RYzen Sun,
I will get my coat![]()
It's not hard to find almost any review that finds the Noctua D15 come top in group tests, even against most AIOs. I don't know why people fall for the 'liquid cooling' marketing nonsense of AIOs over and over... D15 will trump them all for performance and certainly value. I totally get the AIO argument from an aesthetic point of view (especially vs Noctua) or if you have extremely high profile RAM or no height clearance in the case. Otherwise, it's quite amusing reading comments that have owners of AIOs questioning why they don't have amazing near record breaking temps. Do your research lol!!
Same here, along with Prime, very good stability test.![]()
How much trouble did you get into?I won't answer any direct questions, there is an NDA. I will not risk, violating it, I will just give you snippets and some insight, more so than anyone else does apart from our sister company Caseking, so be sure to sign up to their FB and Youtube channels as well.![]()
Thx for hint again Gibbo 1700 it is thenI rate a rock solid 1000MHz+ overclock as a solid overclocking CPU, especially when cooled with just a 120mm AIO.![]()
Technically, in 25h.NDA lifted?
Ryzen 1700 & 1700X benchmarks leaked:
Looked bit blurred as I am try to guess the numbers...
GTA V DX11
Ryzen 7 1700 167fps
Ryzen 7 1700X 130fps
Core i7 7700K 190fps
Core i7 6800K 145fps
Alien: Isolation DX11
Ryzen 7 1700 163fps
Ryzen 7 1700X 194fps
Core i7 7700K 165fps
Core i7 6800K 200fps
Battlefield 4 DX12 ??? I guess it a typo so it should read as Battlefield 1
Ryzen 7 1700 94fps
Ryzen 7 1700X 111fps
Core i7 7700K 93fps
Core i7 6800K 115fps
Ashes of the Singularity DX12
Ryzen 7 1700 44fps
Ryzen 7 1700X 55fps
Core i7 7700K 44fps
Core i7 6800K 56fps
Civilization VI DX12
Ryzen 7 1700 63fps
Ryzen 7 1700X 67fps
Core i7 7700K 73fps
Core i7 6800K 79fps
DOOM Vulkan
Ryzen 7 1700 101fps
Ryzen 7 1700X 127fps
Core i7 7700K 94fps
Core i7 6800K 123fps
Hmmm very interesting peformance but I noticed something wrong with 1700X GTA V fps is lower than 1700, it probably another typo.
Look like 1800X OC will have no problem smash 7700K in every games benchmarks.![]()
I went from Noctua and Phenteks to the Corsair H100i over 3 years ago for these reasons:
The fact is, AIOs like the H110i and H115i now are basically the same performance as the high-end air. You just pick whichever is best for you and your build. Not comprehending why people choose AIO over the traditional heatsinks is just silly. Both are excellent choices.
- Less faffing
- Aesthetics
- Performance was the same, better even in some cases, with little to no difference in noise
- Less worry of weight on motherboard
Sure, don't expect it to be 10c+ cooler, that's madness. You want a proper watercooling solution for that, but that's a whole different kettle of fish.
Interesting, I wonder how stock is gonna look like after tomorrow's reviews, benchmarks etc.
So reading into your post, the first load of Ryzen samples were garbage so the motherboard vendors couldnt be bothered to really put any effort into supporting them, so AMD respun the chips and sent them out again and at this point the motherboard vendors were like "ooh yeah now its decent, lets make some motherboards for it" but this was obviously the cause of the delay in no one getting motherboards other than Asus shipping their out, and the lackluster selection we currently have of motherboards.
And ontop of this the Memory thing still has not been totally sorted yet, and its something likely to be patched in as and when memory vendors get their stuff to AMD to be certified and sent back?
All i want to really know is, can the 8/16 Zen chips beat my 4.3 4770k in Single thread and multithread performance, while keeping cool, and can i run some decent timed ram alongside it on a motherboard with some decent storage options and potentially xfire.
you'd thought they would offer their full range to Mobo vendors to get them Cert!
