- 17 Sep 2007
- West Yorkshire / Market Bosworth
I'm not sure, they have those newfangled keys, I get the feeling the OP is more of a crank-handle kind of guy.
OP Reminds me of this scene.
Sounds like OP needs a 1990 Fiat Panda.
Porsche 911 r
No?Nah, I had a great Octavia and let it go. I can't imagine being able to get one as nice as the one I had so that puts a downer on me getting another.
Well.... yes.... no.... sort of....Hate to say it but your using those things wrong.
My manual says 22ºC.Climate control should be set and forget really. I only really adjust the temperature on particulary hot or cold days, otherwise it stays on 20 degrees/auto.
Same on my car, except it switches off every time you turn off the engine, so you have to turn the auto off and back on again every time.Don't know what is going on with your auto wipers. Push the wiper stalk one notch up on all the cars I've driven turns auto wipers.
One of the reasons I love my Mercedes is that there's little to distract from the process of actually driving it.
Very straightforward and uncomplicated. Even more relaxing, as a result.
No?
Some great examples out there right now, for quite reasonable money, too...
However, while that does work exceedingly when I want exactly that, what I want from it at other times is often different.
For example, in the recent weather I have often had my window open about an inch or two so I can get some fresh air and avoid overheating, but I have the vents blowing 24ºC air directly onto just my hands.
Neither, really.Sounds more like a user problem then a issue with the car.![]()
Fantastic and this is really what I'd love to see available in years to come- simple and oozing quality, zero faff to distract you.
I'm sure manufacturers could do a modern take on that and it would be sublime, I'm also sure that there would be very little market for it unfortunately![]()
It certainly has and I'm not against the technology thats for sure, I just don't want that technology to come at the expense of distraction and over complicationTechnology has made huge leaps since that car came out
Would I go out of my way to spec it? Probably not as it goes out of date and I drive older cars so for me mobile integration would be better.
I'm happy enough with the one that I have but TBH it was the ND (or mk4 to most people) that initially got me thinking about this. When they feel the need to slap on a colour touch screen on an MX5 of all things then things have gone to far. I literally mean slap on as well because they've gone the Mercedes after thought look with it. The most basic model doesn't have it but that instead gets a nasty looking radio that manages to look equally stuck onDon't know why you wouldn't like a new/newer model mx5. It's kind of stayed true to the original but with a few more creature comforts. Electric convertible roof for one thing.
The convertible has a manual roof though, not electric.
