Just booked a holiday to Canada in a fortnight so have two 8 hour flights that will be ideal Zelda time! Just need to find a compatible power bank as apparently you need a native USB-C one for it to charge the Switch properly.
One day to go Brosefs![]()
Don't worry mine was like that earlier, then it changed. Give it a few hours.My Amazon status says Arriving Tomorrow, but not yet dispatched.
Nooooooo... mine does not have USB C....Just booked a holiday to Canada in a fortnight so have two 8 hour flights that will be ideal Zelda time! Just need to find a compatible power bank as apparently you need a native USB-C one for it to charge the Switch properly.
Looks to be a bog standard power bank, so any should work surely?
AUKEY Power Bank 20000mAh currently £16.99
I believe the switch charger is like 5 volts, hence why the power banks reportedly do a poor job with feeding them enough power to recharge the battery whilst playing.
Normal USB charging is 5V. The Switch (according to reports) charges fastest at 15V which can be negotiated with a native USB-C charger. 15V charging over USB-C is pretty new so personally I would wait a week and find a charger that's been successfully tested with the Switch.
Hopefully it will turn out that other chargers can still charge the Switch, just much more slowly.
.Same here, still says will dispatch.Man, my order hasn't budged. Fingers crossed it does soon!
