Too far away from my router
Do you have any other pc's in the house ?
I did a dirt 1.35v for both, haven't dropped the volts to find a sweet spot.
3.7Ghz is sub 1.16v, not dropped the volts yet on that either.
EDIT: Wow, I see people at 4Ghz with 1.5 volts, hopefully I can hit 4Ghz at sub 1.38, that be a touch.
EDIT 2: 1.35v 60c on load air cooled.
Yep apart from my monitor, for some reason if it doesn't detect a signal right away it goes to sleep and I can't stop it doing it so I can't get into the bios to do anything
Lg super wideWhich monitor?
You guys will never believe this it's the monitor that has not picked it up, on the off chance I plugged it into my TV and it went straight into the bios
Great ...glad you got it working ...now you owe us all a mass amounts of info re your benchmarks
good point..Wonder how many reviewers used these.
good point..
@harney
Check bottom page you will need to translate. Your memory or 1 set above as in 3600, but might please you. Look Cpuz
Reason I was looking for some to Samsung B one sided I think.
https://www.computerbase.de/2017-03/amd-ryzen-1800x-1700x-1700-test/
Lg super wide
I had this problem with asus am1 and a r7 360,
It wouldn't boot using tv but using a monitor it would then work.
In the bios i disabled the csm mode and this enabled the board to detect my tv at post.
Worth a go but you'll have to use your tv then power off and try monitor
I tell you what it's not my night, started to update the bios it was doing its thing the it switched off switched back on said it was updating switched its self off right away and now it's doing nothing
Yes but it's not posting nowhave you got a bios on a usb stick ?
