3ds all over again?
Same Tauren, I've not really had any issues and just had a 2 hour session of 1-2 Switch with mates there! Mines is behind the TV as well, problem is being blown out of proportion.Mines fine. Dunno what all the fuss is about. And it's pretty much docked halfway behind my tvno issues.
Not saying it isn't there but people are probably actively trying to recreate it. Hopefully some firmware/software updates will improve the situation however!
the top screen would get scratchesI didn't know about the 3DS. Never bought one when it came out.
Hold the power button down, then select power options, shut down.
Had about an hour playing with Zelda, Switch is definitely a good system. Quite impressive for a portable. Even though i was kinda against buying one until they hit a cheaper price, i got one with Zelda for 303.99 so not bad overall. I look forward to seeing what type of games come out for it, hopefully a lot from the SNES era like Pilotwings etc.
Agreed, the price is fantastic as I hear it feels quality too, which is a Nintendo trademark. It's just allocating time for me... PC, X1, PS4 + Retro, I do want a handheld though as Smartphones, Vita and 3DS(crappy right stick, and lack of buttons) just don't do it for me.
I was doing the same, but 50" creep and 2-3 foot away. Never had an issue. But then I got my pro controller from Very and been playing with that since. The pro controller is very good, I would consider picking that up in your situation.Sitting on the couch playing in the same way I would with the PS4 is not actively trying to recreate it.
Taking a bean bag and sitting 4' away from a 55" screen and it still happening is infuriating. I can only assume it's very sensitive to other wireless devices or some of the internals are faulty in some of the left joy-cons.
I assure you it's very real, very annoying and certainly not a problem I want to have to put up with.
Mine were charging while I was playing on my pro controller, they both fully charged. In main menu under controllers you see if it is charging or not, maybe your did not click in properly.Anyone's left joy con remote used way more battery than the right? My right one is still showing as full but left is down to red.
I thought leaving them on the machine when docked would charge them? Even in sleep mode? What is the best way to charge them?
I've been using them in the grip pretty much exclusively.
