Gibbo have you tried to disable XFR and boost on a 1800X, and try clock it to it's limits?The 1700 actually ran a good 10c cooler.![]()
I think people were saying air and water 1700, ln2 1800x,1700x ...nobody knows![]()
Thanks Gibbo the review and advice.Yes in the Asus Crosshair!
B350 motherboards seem to be very weak for overclocking at present, so avoid those if OC.
Tried MSI 370 SLI board, CPU overclocked OK, but refused to run beyond 2400MHz RAM, clearly BIOS bug.
So in short Crosshair is the only board I can recommend.
We should get the Taichi tested tomorrow which should be a good one hopefully.
For me 1700 is obvious choiice. Runs cooler than 1800X. OC to same level.... Absolute no brainer!!
do you think 4ghz is going to be a realistic 24/7 oc on a 1700 + Taichi? will be using corsair h110i extreme performance AIO
Oh... sounds very sweet
What do you mean by.. fine? For me, fine temps are below 65C under water on overclocked CPU.
