ahh man that would have been a lot easier if it did. Yea only other option is what others have suggested. You have to make a flash drive with the bios. Ive done it before but i ended up requiring another computer to do it and it took a lot longer. Asus have a ultility that makes & prepares the flash drive and u just pop it in your computer and turn it on usually. Not sure if post needs to pass in order for it to work tho.No the asus board doesn't have that
8Pack knows his stuff.It's not B1 mate it's error 61b1 is memory related usually.
Try different dimms with only one dimm in the board.
I have tried the asus flashback procedure which seems to work, I say it seems to work what I mean it's completes its cycle , it now hangs on error 61ahh man that would have been a lot easier if it did. Yea only other option is what others have suggested. You have to make a flash drive with the bios. Ive done it before but i ended up requiring another computer to do it and it took a lot longer. Asus have a ultility that makes & prepares the flash drive and u just pop it in your computer and turn it on usually. Not sure if post needs to pass in order for it to work tho.
edit -
^ Big man has spoken.8Pack knows his stuff.
Eh no point to waste more time, if you do not have other ram stick to use, pack motherboard and ram and send them back for replacement.I have tried the asus flashback procedure which seems to work, I say it seems to work what I mean it's completes its cycle , it now hangs on error 61
Yeah that's what I'm in the middle of doing.Eh no point to waste more time, if you do not have other ram stick to use, pack motherboard and ram and send them back for replacement.
i think you may be right,
I'm thinking the same as you, I have the 1700x on order and thinking about changing it for the 1700 but have this niggling doubt that I should stick with the 1700x
Is there a rough idea of when we expecting zen based APUs?
My son is currently using a 3ghz core 2 duo machine with a hd 7750, which kinda does the job for minecraft and roblox etc, but hes going to want a bit more soon, and a zen APU with current AMD graphics tech and ddr4 would be a fantastic upgrade for presumably reasonable money...
Ok I am home, lets get testing.
I don't even have my DPD email yet, lol. This wait! Rip.Well I'm camped at the front door for the next two hours. DPD slot of 10-11am
I'm not sure they will have a Vega chip. I think more likely polaris likely similar spec to a rx460 which would still be a really good APU. Though I'm happy to be proven wrong on this scoreSummer time, we going to have the Ryzen APUs with Vega IGP.
