Looks like time to completely ignore the reviewers and wait for the guys at overclockers to post their result.I agree on that. Especially those using the Asus CH6 Hero show completely different perf compared to Gigabyte motherboards, and the difference is big.
(pointing at Joker's video at 1080p with the GTX1080 also).
Also we do not know how many of them had patched with the CH6 Hero with last weekends BIOS, which resolved many issues.
And we have just B350 Tomahawk, for less than half the money the CH6 Hero not only overclocking better, not only supporting better ram timings and speeds, but requiring less power to overclock the CPUs!!!! Even with the stock Wraith cooler, or just simply the Notcua NH-U12S
How high can the temps on these safely go?71 c totally fine push it further.
Ok this just got very interesting https://www.facebook.com/theoverclo...46028454.301569.72682703453/10155035829263454
Edited to add Reddit Thread https://www.reddit.com/r/Amd/comments/5xdxvy/the_overclocker_magazine_that_moment_when_your/
So here is my Cinebench results:
R7 1700
MSI B350 Tomahank
16GB Crucial 2400Mhz DDR4
Notcua NH-U12S
EDIT: BIOS V1.0
Power = Performance mode but sure no different with balance.
Fresh windows 10 Installation
3.6 @ 1.104v
3.7Ghz @ 1.176v
3.8Ghz @ 1.224v
3.9Ghz @ 1.304v
4Ghz nees over 1.4v and the heat output rockets at 1.4v so on air I am not pushing that. Topped at 71c but I am not sure what these CPU's can take and wouldn't want to brick it.
Just to add, 3.65Ghz @ Stock volts Real Bench H254 5 runs with ease.
What should I bench now?
do you have a laser temp gun scrams if so would love to know the temp of the cpu vrms while on load...i think once he has install the os on the tv should be fine once it boots into windows but yeah strange one not to see the bios / post
Well that's a Prime B350-A matx board ordered for delivery tomorrow and another crosshair on back order for a few weeks time hopefully it will work this time
Some games like threads more than Mhz.
Your not going to get any disagreement from me I might change it to the gigabyte board I have always used asus though£250 board and no dual bios, terrible.
The guy has stated that he patched his Asus CH6 Hero with the last BIOS, which includes the last microcode (CPU firmware upgrade) by AMD.
And the performance boost was big, compared to the initial review he did, even if still using the same 2133 memory. That microcode resolved an issue between the CPU and the IMC.
In addition, running Windows on balanced mode prevents Ryzen from switching clockspeeds and voltages any faster than 30ms.
If the windows are set on High performance, it allows it do go into 1ms, full speed, switching. Imagine how faster the CPU->GPU communication is when the entire CPU is allowed to be 30 TIMES more responsive with boosting?
Which shows, all issues are software related.
I have not used the stock cooler. I would prob add 5-10c on this cooler for them. Temps are really good, 50s and 60s.
R7 1700
MSI B350 Tomahank
Notcua NH-U12S
EDIT: BIOS V1.0
3.6 @ 1.104v
3.7Ghz @ 1.176v
3.8Ghz @ 1.224v
3.9Ghz @ 1.304v
Please can you say which cooler are you using? Also which memory?
