- 26 Sep 2013
- West End, Southampton
I set mine like this, I don't use Wattman
I have the same GPU and not had a single issue so I have no idea what is going on Nexus
U ready for division test mate?
Ah cool, thanks.Wattman lists actual voltage and you can adjust it in 0.5v increments. For example Fury X stock voltage of 1.231v will show as 1.230v in Wattman and you can increase it to 1.235v, 1.240v, etc. Same for decrease.
Well so far the newest drivers without relive installed are working pretty well for me now (haven't enabled wattman and still using MSI AB) so got to be something about relive causing the problems. No biggie for me as I never record/stream and got MSI AB for screenshots.
Hoping for some help.
Just brought a new XFX 480 8gb GTR model on Thursday, since then I've seen graphical corruption during game-play. Screen would go black then eventually come back on like nothing has happened. Checked event logs and can see AMD graphics have stopped errors. Now I've been on nvidia for last 4 years with not a single issue, is this still a problem with AMD (drivers, and the reason i changed back then)
Do i have to go through previous drivers to find one that works?
Cheers.
Do you have Relive installed?
If yes, do a clean uninstall, then custom install & avoid Relive.
I had problems & that worked for me.
This is some of what I get when launching a game, or in a game.
Sorry for quality of last pic, had to quickly take it haha.
Nope I dont do overclocking.
Like I said my machine been solid using my 770 before I switched, so can't see it being anything other than this card/driver issue.
