Can i be a pain in the butt and ask for st results from each clock speed?Ok to add with these results:
4.0Ghz @ 1.400v - topped at 72c
Glad to hear this ....This M$ power management has always been an issue for any cpu speed-stepping ect great for power saving but usually creates high DPC ...
Lets hope M$ refine it better for th Ryzen chips
True and isn't only the 720p but the 1080p video with the 1700 @3.9 vs 7700K @ 5GhzNot sure if someone has already posted this, but 1700 Ryzen delivering a much smoother gaming experience than the 7700K @5Ghz.
Amd rushed to get their Avfs setup, like we all agree, they should have delayed a couple of months to get everything setup, tested and qualified. Considering they had this syatem in carrizo and bristol ridge the performance plan bug should have been spotted. Now you may think i'm over critical but look at the bugs, look at the lack of motherboards, look at thr bios patches, no hdmi2 on the boards. It's a last minute rush job.
On a positive note, scramz is having a cracking time
At least people are getting to play around with it all now, sure there's bugs but they'll be ironed out
I'd buy today even with the bugs
MS is slow -_- They still have to release also a patch to resolve the schedulers, which bounces the processes between different CCXs. According to AMD this is due at latest by end of the month by Microsoft.
True and isn't only the 720p but the 1080p video with the 1700 @3.9 vs 7700K @ 5Ghz, and thought that the Ryzen was smoother than the KabyLakes, no is not your eyes.
https://www.computerbase.de/2017-03/amd-ryzen-1800x-1700x-1700-test/4/#diagramm-f1-2016-frameverlauf
It shows the Frametimes on the Ryzen CPUs is much better than the Kabylake one, even if the latter might have higher max on some games.
Hence the Ryzen video was smoother than the Kabylake.
1700 @ 4.0Ghz Single Thread.
So here is my Cinebench results:
R7 1700
MSI B350 Tomahank
16GB Crucial 2400Mhz DDR4
Notcua NH-U12S
EDIT: BIOS V1.0
Power = Performance mode but sure no different with balance.
Fresh windows 10 Installation
3.6 @ 1.104v
3.7Ghz @ 1.176v
3.8Ghz @ 1.224v
3.9Ghz @ 1.304v
4Ghz nees over 1.4v and the heat output rockets at 1.4v so on air I am not pushing that. Topped at 71c but I am not sure what these CPU's can take and wouldn't want to brick it.
Just to add, 3.65Ghz @ Stock volts Real Bench H254 5 runs with ease.
What should I bench now?
Can people share what sort of idle temps they are getting at these 4ghz clocks? interested to see if we're all around the same mark.
3.9Trying to find my sweet spot, 3.7Ghz at sub 1.2 volts seems nice. Or should I just go for 3.9 @ sub 1.31 for 24/7?
