So many benchmarks are at 1080p and many even at 720p (!?), so if you're at ultrawide for example (3440x1440) and have a 1080 or 1080Ti, how do you make sense of these, and therefore how does that impact CPU choice for a gaming system... i.e if you were looking at the 7700K vs 1700X/1800X, or possibly the 6C 1600X. And for arguments sake, let's say you will be custom watercooling, so max clocks can be achieved. The latter three are all going to top out around the 4GHz mark, but you will comfortably hit just under 5GHz (possibly over) on a 7700K. Thing is, if you're really pushing the resolution at ultrawide (or even 4K), won't the GPU be the bottleneck, and not the CPU?
Value/performance argument aside, which I know AMD win, should your money go to Intel or AMD if you want the best FPS and overall raw performance? Does the future proofing argument make sense, i.e with more games in the future taking advantage of those cores, or does the resolution + top end GPU make that a far weaker argument?
