Notua cooler arrived and fitted so thought I'd give mine a workout.
Similar results as @Scramz 3.9ghz at 1.31 volts then a big bump over 1.4v needed for 4ghz
Starting to seem like 3.9Ghz is the sweet spot, 4.0+ Ghz needs big voltage
Starting to seem like 3.9Ghz is the sweet spot, 4.0+ Ghz needs big voltage![]()
Its happy to sit at 4ghz 1.4v tho i think right? what kinda temps does it idle and max at with that cooler @ 4ghz?
^ great achievement... Really force the last bit of performance from the Cpu lol
Idles in the low 40s on High Performance power mode so no downclocking. Maximum temps loading it up with Folding@Home was 63c and that really does give a CPU a solid workout.
Edit: I've actually dropped back to 3.6ghz on stock volts as I'm really not going to need those extra 300mhz any time soon
8 Pack, when you going to post the results from your trials with the Taichi and why the 1800X is running 10C hotter than the 1700?1.45v top voltage 24-7 as advised by amd. Temps top is 95 but for me 80-85 is enough.
@ Scramz are you actually clocking the processor from within the bios or are just using software? That would explain things a little. As your clock is after windows has loaded and the tool which I would prob never used is adjusting in some way rather than having a fixed vcore set in bios?
Thanks man!Nice clean build.
Ghost Recon Wildlands
1080p with GTX 1080 1060/RX480
7700K 5Ghz vs 1700 3.9Ghz
I am not using fixed volts for my OC.
4fps difference vs a 5ghz kaby lake not bad! Although i bet it would be different if paired with a better GPU.
If they were at the same clock speed I doubt we'd see any difference in the game as well.
Here's hoping R5 can manage to up the base clock speed a bit more so gamers can be happy.
I would like if people could test the 6900K and R7 head to head in these newer games as well.
