*** AMD "Zen" thread (inc AM4/APU discussion) ***
9 Nov 2009
Planet Earth
OK,a mate is showing some interest in a R7 1700(not really for gaming though) and he won't overclock. What is a solid board for him say at £80 to £150 currently??
He might be running it at full load for a few days(or a week or so) at a time. A decent number of SATA ports would be useful.
Permabanned
15 Oct 2011
Nottingham Carlton
^ great achievement... Really force the last bit of performance from the Cpu lol
Hows Those Asrock motherboards looking ?? You had time to play about with them yet ??
I went asus due to... USB Ports..... Oculus rift with controllers and 3 cameras = 5 usb ports thats why i went with Asus with whole army of USB's
25 Jun 2013
Warks
From what i have been reading r7zen performs better on 7 i am about to build and test a ryzen build later tonight and test 7 vs 10
It'd make sense if the scheduler isn't as buggy. Right now if you leave SMT on you get a performance drop from bugs, if you turn it off you lose a ton of potential performance.
22 Nov 2009
Under the hot sun.
On the Ryzen gaming thread in here, shows that Ryzen gets a hefty boost on gaming by up to 30% on windows 7 compared to 10.
When I have the stuff next week (waiting 8pack to give us some feedback on the Taichi), I will make an extensive benchmark list and differences. Since I am going to use 2 drivers each with different version of windows.
And also post benchmarks on speeds 3.9-4-4.1 regardless the power draw.
Since it is going straight away under the Predator 360
Man of Honour
13 Nov 2009
Northampton
Not a single issue so far with my Gigabyte B350 Gaming 3 (Only 6 SATA ports though)
7 Sep 2014
A friend has mentioned (and he generally knows his stuff) that Ryzen has quite a few new instructions added to it's instruction set, which is why the performance isn't quite there yet. How much truth is there to that?
8 Jul 2013
Middle age travellers site
Hearing good things re MSI tomahawk ...problem not so many sata's
9 Nov 2009
Planet Earth
Been seeing great results on other threads with the tomahawk and scramz on here is doing well with it too .....
Is it possible to use a pcix sata card with the ryzen to add more
It will be all run at stock since its bioinformatics type stuff,which runs for days at a time,maybe longer.
Although its not really required,do any motherboards support ECC memory,as IIRC the Ryzen IMC does support it(I think)?? If it doesn't its not a biggie since it is silly money anyway.
