For people who look for 980Ti OC vs 1080 TI OC results this is a good review:http://www.pcgameshardware.de/Gefor...kkarte-265855/Specials/Test-Review-1222421/2/
Not impressed with the new cooler, looks like after market cooler or water still
AMD Ryzen 7 1800X + NVIDIA GeForce GTX 1080 Ti. Match made in heaven! Ultimate performance!
https://twitter.com/roy_techhwood?lang=en
AMD ROY approves lol. Trying to shift Ryzen using the gtx1080ti.
Looks like it is designed for stock usage. It will take some power boost, but struggles with manual higher overclocks.There are oc results.
1080 Ti + Ryzen review below at eTeknix
http://www.eteknix.com/nvidia-gtx-1080-ti-cpu-showdown-i7-7700k-vs-ryzen-r7-1800x-vs-i7-5820k/
Specifically for the GTX 1080 Ti Founders Edition, though Nvidia says it has an improved cooling design, our research indicates the underlying GPU is still being held back, and we expect to see more performance and quieter acoustics as the better AICs turn their hand to designs.
Kinda makes you wonder what Vega is bringing?That bloke is not the full ticket. He might be advertising Ryzen but at the same time he is also advertising Nvidia.
38"? I need to do some googling lolOr isn't
If the 38" Gsync screens are out before Vega then I'll have a decision to make! Esp if it's 4-5 weeks before...
I assume that on water, the GPU will be totally fine? So a FE on water should performance equally as well as a custom cooled GPU? Ir not better.
Got any links Jed? I have done some quick googling but nothing much found![]()
