Man of Honour
Has anyone had luck getting cashback and/or gift voucher cards on a 'New Customer' deal by starting a new contract with BT? I'm wondering if this works.
6db is excellent why is that a problem ? I get 56meg and I`m on 5db.Still not seen my noise margin target move, currently sat at 6db![]()
I've had a problem for the past few weeks where my speed has been dropping considerably in the evenings and running at about 8Mb. During the day it was fine and hit max speed (~52Mb).
I just thought it was congestion but raised an issue with BT and they said there was a cabelling issue or something in the exchange. True to their word a couple of days later it was fixed and back up to full speed.
Any idea what this might have been? When they called back it was a dodgy line and I couldn't really hear them well enough to ask lots of questions.
Guys,
I am a new BT customer as of last Tuesday but I need to use a modem so I can get my ASUS router back up and running,can I just go to ebay and buy the first openreach modem I see or is there more to it than that?
Cheers.
Yeah get an Openreach modem, should work fine. No idea about BT TV I'm afraid but I don't see why it wouldn't work.
Also will using an old router affect the BT TV in any way,like **** it up?
Can't you use the Pi-Hole for DHCP as well as DNS? If it will handle DHCP and the DHCP server on the HH5 can be disabled you should be good-to-go.
If you're after a VDSL capable router for £50 I think you'll struggle.
yep speed doesn't seem a problem just resolving websites seems a little slow and at time nothing, seems okish now though
I quick Google shows that the DHCP server on the HH5 can be disabled. It also does look like there's some support for running the Pi-Hole as a DHCP server. It'll cost you nothing but a bit of time to try it.The router doesn't even have to be a good one as it will only be connected to the phone line for incoming connection and DHCP and then an Ethernet cable to the HH5 that will be set up in as a repeater that I connect all devices to. Will that work or is using Pi-Hole better and easier? I guess it saves on having to buy more devices.
