Thanks for the advice guys. If I can get a good price for my current ram, I will upgrade to a faster speed this month.This video shows how ram speed can effect certain games a fair bit.
After all those reviews, do you guys still think its good idea to buy FE version? I mean cooler/throttling/noise levels.
I'm asking cause I never had reference design card, always third party cooler versions...
I'm worried that this will be too noisy for me etc.
Nvidia order is still stuck on processing since early this morning, looks like no Ti's for me until Monday![]()
I saw FE cards boosting to 19xx out of the box that to me is reasonable! id expect AIB cards to hit slightly higher stated boost but out of the box AIB cards will boost and hit slightly higher as in just under 2ghz but obviously while remaining cooler and quieter.Imo at stock the fan profile remains reasonably quiet. However in turn it does not boost very high compared to aftermarket cards. Said cards will run reasonably quiet also while achieving a high boost. Founders has it uses but for most aftermarket will be better.
same, with boxed mentioned next to it. The only reason I ordered from them was to hopefully have it tomorrow - but seeing how damn incompetent they are, unable to provide any info and messing me around to day, i've decided to cancel and just wait it out.
same as me to. Any chance of them delivering saturday?
They will usually boost pretty high and during most tests they do not last long enough that it causes any throttling. But play for at least 10 mins or so and use the stock fan profile and the cards will get warm enough that I would be very suprised if it will be able to hold over 1900 mhz constantly. I know my 1080s can't nor could the pascal Titan x (all FE coolers) I had hold that sort of figure. Andtech also shows similar patter with game tests where the card can get warm enough where the clock is a fair bit lower then what it was boosting too when running cooler. http://www.anandtech.com/show/11180/the-nvidia-geforce-gtx-1080-ti-review/16
Definitely need waterblocks to keep the cards running at a constant overclock.
Here is my Pascal Titan running the Valley bench @2160p at well over 2100mhz, something none of the air cooled 1080 Ti's tested today can get close to.
