And? Again all this proves is some software isn't well optimised yet. It's clear to see that the 1700 is barely breaking a sweat.
Fallout 4 one of the oldest engines around, based on the Fallout 3 engine which in turn was based on the Oblivion engine which was released 11 years ago.
Same poster also does a Crysis 3 vid where it matches the 6700K, I would guess it's more a fallout issue (or down to drivers) than a CPU issue.
I saw a slide at some point that showed only the 370 board did SLI\Crossfire...is that wrong or did I go mad and not see it?
Ah yes apologise, you can do crossfire on B350 but have to go X370 for sli for some silly reason :/ so really yeah I guess if you are going dual Nvidia go X370 and otherwise B350. Either way though there still no reason to pick the ATX board of the MATX board when cheaper with same features.
Maybe people like the visual appearance of a larger board in their case.
ATX boards look better in a bigger case. I think the Gaming 3 has better VRMs, an extra rear panel USB, better on board audio, better bios support, an extra PCIE slot
In fairness the same was true of the 5820K and at the time benchmarks showed it didn't make any difference (there was a 1-2 FPS difference in some games compared to the 5930K but that was put down to the CPU).Ryzen can only do 8x PCIE in xfire/sli regardless of number of slots.
That is true and maybe the biggest reason to go for ATX. But that doesn't actually make the boards better for the extra cost and it actually used to be a premium to go MATX which isn't the case now. I think given time there are also reason to allow more space in a case for things such as better cooling, more cable space etc.
I chose atx over matx for one reason. It was actually in stock! I even changed my case to suit because I'm an inpatient child.
Yep I understand but from what I also remember it drops more going from 8x to 4x and so 3 way would give much more issue than xfire/sli and thought maybe that was why AMD feel the sweet spot at this time for consumer is what they have provided?
1700@4000Mhz getting spanked of a 6700@4000Mhz, under 60 FPS in some areas on ryzen this with a 1070, i would not be pairing it up with a 1080ti.
In almost all tests (things didn’t go perfectly in Far Cry Primal) the Ryzen 1800X gave the best frame rates at all resolutions, and even more so when pushed to 1440P and 2160P, where the 8-core 16-thread design of the CPU was able to relieve the GTX 1080 Ti of any bottlenecks in performance.
The gaming 3 is available in both MATX and ATX with same features bar the one extra PCIE slot but that I feel unless you are really wanting to put a sound card in is redundant bearing in mind the number of PCIE lanes available. Ryzen can only do 8x PCIE in xfire/sli regardless of number of slots.
I don't believe you can do three way on AM4?
Not sure about other boards but on the Gigabyte Gaming 5 the third x16 slot is only x4 and is wired to the PCH not the CPU (it's aimed for NVMe storage). Also I think Nvidia disable SLI at 4x? (and disable >2 car SLI with Pascal?).
the atx version has better onboard audio I think. Also worth considering that the 16x pcie on the matx version is 1 slot closer to the CPU, so the graphics card could potentially interfere with some of the larger CPU coolers.
I'm very close to ordering the gaming 3 and another reason I won't be getting the matx is also that the second gpu is going to interfere with the front panel usb3 header. Oh and also no bling bling![]()
